Custom Dynamic Shape¶
Here, based on the previous project, a continuous animation of Pac-Man eating dots will be created.
Run the code
When the program is running, you will see Pac-Man on the RGB matrix cap move from left to right and leave after eating the rightmost dot.
cd /home/pi/rgb_matrix/raspberrypi
sudo python3 custom_dynamic_shape.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like rgb_matrix/raspberrypi. After modifying the code, you can run it directly to see the effect.
from rgb_matrix import RGB_Matrix
import random
def pacman(a,k):
list2 = [[a-4,0,a-1,0],
[a-5,1,a,1],
[a-6,2,a-5,2],
[a-3,2,a-1,2],
[a-6,3,a-2,3],
[a-6,4,a-2,4],
[a-6,5,a-1,5],
[a-5,6,a,6],
[a-4,7,a-1,7]]
fill = (144,192,22)
for i in range(0,k+1):
for j in list2:
rr.draw_line(j,fill)
rr.display()
for j in list2:
rr.draw_line(j,fill=(0,0,0))
for i in range(0,9):
list2[i][0] += 1
list2[i][2] += 1
time.sleep(0.1)
def pacman2():
rr.draw_rectangle(rectangle_coor,fill=(0,0,0))
list = [[2,0,5,0],
[1,1,6,1],
[0,2,1,2],
[3,2,7,2],
[0,3,7,3],
[0,4,3,4],
[0,5,7,5],
[1,6,6,6],
[2,7,5,7]]
fill = (144,192,22)
for i in list:
rr.draw_line(i,fill)
rr.display()
time.sleep(0.1)
def pac():
coor = [6,3,7,4]
rr.draw_rectangle(coor,fill=(82,52,25))
if __name__ == "__main__":
rr = RGB_Matrix(0X74)
rectangle_coor = [0,0,7,7]
pac()
pacman(0,6)
pacman2()
pacman(6,7)
How it works?
pac()
pacman(0,6)
pacman2()
pacman(6,7)
We can disassemble Pac-Man into three actions, pac() represents the position of the dot.
pacman(0,6)means that Pac-Man moves from the far left to the side of the dot.pacman2()mouth closed to indicate the action of eating.pacman(6,7)indicates to continue to leave after eating.
def pacman(a,k):
[a-5,1,a,1],
[a-6,2,a-5,2],
[a-3,2,a-1,2],
[a-6,3,a-2,3],
[a-6,4,a-2,4],
[a-6,5,a-1,5],
[a-5,6,a,6],
[a-4,7,a-1,7]]
fill = (144,192,22)
for j in list2:
rr.display()
for j in list2:
list2[i][0] += 1
list2[i][2] += 1
time.sleep(0.1)
The pacman() function is used to make Pac-man move from the left to the right in an open-mouthed state until it disappears. It has two parameters a and k, a represents the starting position of Pac-man and k represents the number of squares moved to the right.
list2stores the coordinates of Pac-man’s open-mouth state, drawn as lines, with the x-coordinate of each line determined bya.Define a two-level for loop. The inner loop does three things: draws Pac-Man, moves each line in
list2one square to the right, and removes the movement.The outer layer repeats the loop
ktimes, which means Pac-Man movesksquares to the right.
