I2C ConfigurationΒΆ
Step 1: Enable the I2C port of your Raspberry Pi (If you have enabled it, skip this; if you do not know whether you have done that or not, please continue).
sudo raspi-config
3 Interfacing options
../_images/image282.png
P5 I2C
../_images/image283.png
<Yes>, then <Ok> -> <Finish>
../_images/image284.png
Step 2: Check whether the i2c modules are loaded and active.
lsmod | grep i2c
Then the following codes will appear (the number may be different).
i2c_dev                     6276    0
i2c_bcm2708                 4121    0
Step 3: Install i2c-tools.
sudo apt-get install i2c-tools
Step 4: Check the address of the I2C device.
i2cdetect -y 1      # For Raspberry Pi 2 and higher version
i2cdetect -y 0      # For Raspberry Pi 1
pi@raspberrypi ~ $ i2cdetect -y 1
    0  1  2  3   4  5  6  7  8  9   a  b  c  d  e  f
00:           -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
If there is an I2C device connected, the address of the device will be displayed.
