.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 馃憠 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _1.1.5_py_pi5: 1.1.5 4-Digit 7-Segment Display ==================================== Introducci贸n ----------------- A continuaci贸n, sigue mis instrucciones para intentar controlar la pantalla de 7 segmentos de 4 d铆gitos. Componentes Necesarios ------------------------------ En este proyecto, necesitaremos los siguientes componentes. .. image:: ../python_pi5/img/1.1.5_4_digit_list.png Es definitivamente conveniente comprar un kit completo, aqu铆 est谩 el enlace: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Nombre - ART脥CULOS EN ESTE KIT - ENLACE * - Raphael Kit - 337 - |link_Raphael_kit| Tambi茅n puedes comprarlos por separado en los siguientes enlaces. .. list-table:: :widths: 30 20 :header-rows: 1 * - INTRODUCCI脫N DEL COMPONENTE - ENLACE DE COMPRA * - :ref:`cpn_gpio_board` - |link_gpio_board_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_4_digit` - \- * - :ref:`cpn_74hc595` - |link_74hc595_buy| Diagrama Esquem谩tico -------------------------- ==================== ========== === Nombre de la T-Board Pin f铆sica BCM GPIO17 Pin 11 17 GPIO27 Pin 13 27 GPIO22 Pin 15 22 SPIMOSI Pin 19 10 GPIO18 Pin 12 18 GPIO23 Pin 16 23 GPIO24 Pin 18 24 ==================== ========== === .. image:: ../python_pi5/img/1.1.5_4_digit_schmatic.png Procedimientos Experimentales ----------------------------------- **Paso 1**: Construir el circuito. .. image:: ../python_pi5/img/1.1.5_4-Digit_circuit.png **Paso 2:** Ir a la carpeta del c贸digo. .. raw:: html .. code-block:: cd ~/raphael-kit/python-pi5 **Paso 3:** Ejecutar el archivo ejecutable. .. raw:: html .. code-block:: sudo python3 1.1.5_4-Digit_zero.py Despu茅s de ejecutar el c贸digo, el programa realiza un conteo, aumentando de 1 en 1 cada segundo, y la pantalla de 4 d铆gitos muestra el conteo. .. warning:: Si recibe el mensaje de error ``RuntimeError: Cannot determine SOC peripheral base address``, consulte :ref:`faq_soc` **C贸digo** .. note:: Puedes **Modificar/Restablecer/Copiar/Ejecutar/Detener** el c贸digo a continuaci贸n. Pero antes de eso, necesitas ir a la ruta del c贸digo fuente como ``raphael-kit/python-pi5``. Despu茅s de modificar el c贸digo, puedes ejecutarlo directamente para ver el efecto. .. raw:: html .. code-block:: python #!/usr/bin/env python3 from gpiozero import OutputDevice import time import threading # Define GPIO pins for the 74HC595 shift register SDI = OutputDevice(24) # Serial Data Input RCLK = OutputDevice(23) # Register Clock SRCLK = OutputDevice(18) # Shift Register Clock # Define GPIO pins for digit selection on the 7-segment display placePin = [OutputDevice(pin) for pin in (10, 22, 27, 17)] # Define segment codes for numbers 0-9 for the 7-segment display number = (0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90) counter = 0 # Initialize counter for display timer1 = 0 # Initialize timer for counter increment def clearDisplay(): """ Clear the 7-segment display. """ for _ in range(8): SDI.on() SRCLK.on() SRCLK.off() RCLK.on() RCLK.off() def hc595_shift(data): """ Shift a byte of data to the 74HC595 shift register. """ for i in range(8): SDI.value = 0x80 & (data << i) # Set SDI high/low based on data bit SRCLK.on() # Pulse the Shift Register Clock SRCLK.off() RCLK.on() # Latch data on the output by pulsing Register Clock RCLK.off() def pickDigit(digit): """ Select a digit for display on the 7-segment display. """ for pin in placePin: pin.off() # Turn off all digit selection pins placePin[digit].on() # Turn on the selected digit def timer(): """ Timer function to increment the counter every second. """ global counter, timer1 timer1 = threading.Timer(1.0, timer) # Reset timer for next increment timer1.start() counter += 1 # Increment counter print("%d" % counter) # Print current counter value def setup(): """ Setup initial state and start the timer. """ global timer1 timer1 = threading.Timer(1.0, timer) # Initialize and start the timer timer1.start() def loop(): """ Main loop to update the 7-segment display with counter value. """ global counter while True: for i in range(4): # Loop through each digit clearDisplay() # Clear display before setting new digit pickDigit(i) # Select digit for display # Choose the digit of counter to display digit = (counter // (10 ** i)) % 10 hc595_shift(number[digit]) # Shift digit value to 74HC595 time.sleep(0.001) # Short delay for display stability def destroy(): """ Cleanup GPIO resources and stop timer on exit. """ global timer1 timer1.cancel() # Stop the timer for device in [SDI, RCLK, SRCLK] + placePin: device.close() # Close GPIO devices try: setup() # Initialize the setup while True: loop() # Start the main loop except KeyboardInterrupt: # Handle script interruption (e.g., Ctrl+C) destroy() # Cleanup resources on exit **Explicaci贸n del C贸digo** #. Estos cuatro pines controlan los pines de 谩nodo com煤n de los displays de 7 segmentos de cuatro d铆gitos. .. code-block:: python # Define GPIO pins for digit selection on the 7-segment display placePin = [OutputDevice(pin) for pin in (10, 22, 27, 17)] #. Un arreglo de c贸digos de segmentos de 0 a 9 en hexadecimal (谩nodo com煤n). .. code-block:: python # Define segment codes for numbers 0-9 for the 7-segment display number = (0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90) #. Inicializa un temporizador que activa la funci贸n ``timer`` cada segundo. Esto configura el incremento recurrente del contador. .. code-block:: python def setup(): """ Setup initial state and start the timer. """ global timer1 timer1 = threading.Timer(1.0, timer) # Initialize and start the timer timer1.start() #. Despu茅s de que el temporizador alcanza 1.0s, se llama a la funci贸n del temporizador; se suma 1 al contador, y el temporizador se usa nuevamente para ejecutarse repetidamente cada segundo. .. code-block:: python def timer(): """ Timer function to increment the counter every second. """ global counter, timer1 timer1 = threading.Timer(1.0, timer) # Reset timer for next increment timer1.start() counter += 1 # Increment counter print("%d" % counter) # Print current counter value #. Desplaza un byte de datos al registro de desplazamiento 74HC595, controlando los segmentos de la pantalla. .. code-block:: python def hc595_shift(data): """ Shift a byte of data to the 74HC595 shift register. """ for i in range(8): SDI.value = 0x80 & (data << i) # Set SDI high/low based on data bit SRCLK.on() # Pulse the Shift Register Clock SRCLK.off() RCLK.on() # Latch data on the output by pulsing Register Clock RCLK.off() #. Actualiza continuamente la pantalla con el valor actual del contador, mostrando cada d铆gito secuencialmente. .. code-block:: python def loop(): """ Main loop to update the 7-segment display with counter value. """ global counter while True: for i in range(4): # Loop through each digit clearDisplay() # Clear display before setting new digit pickDigit(i) # Select digit for display digit = (counter // (10 ** i)) % 10 hc595_shift(number[digit]) # Shift digit value to 74HC595 time.sleep(0.001) # Short delay for display stability #. Limpia la pantalla de 7 segmentos apagando todos los segmentos antes de mostrar el siguiente d铆gito. .. code-block:: python def clearDisplay(): """ Clear the 7-segment display. """ for _ in range(8): SDI.on() SRCLK.on() SRCLK.off() RCLK.on() RCLK.off() #. Selecciona qu茅 d铆gito de la pantalla de 7 segmentos activar. Cada d铆gito es controlado por un pin GPIO separado. .. code-block:: python def pickDigit(digit): """ Select a digit for display on the 7-segment display. """ for pin in placePin: pin.off() # Turn off all digit selection pins placePin[digit].on() # Turn on the selected digit #. Libera correctamente los recursos GPIO y detiene el temporizador cuando el programa es interrumpido. .. code-block:: python except KeyboardInterrupt: # Handle script interruption (e.g., Ctrl+C) destroy() # Cleanup resources on exit
