1.17 Rotating fan
In this project, we will make a spinning star sprite and fan.
../_images/1.17_header1.png
../_images/1.17_list1.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Power Supply Module
L293D
DC Motor
Build the Circuit
../_images/1.17_image1171.png
Load the Code and See What Happens
Load the code file (1.17_rotating_fan.sb3) to Scratch 3.
After clicking the green flag on the stage, click on the star sprite,then it and the motor will rotate clockwise; you can change the direction of rotation by clicking on the two arrow sprites. When you click on the star sprite again, it and the motor will stop rotating.
Tips on Sprite
Delete the default sprite, then select the Star sprite and the Arrow1 sprite, and copy Arrow1 once.
../_images/1.17_motor13.png
In the Costumes option, change the Arrow2 sprite to a different direction costume.
../_images/1.17_motor21.png
Adjust the size and position of the sprite appropriately.
../_images/1.17_motor31.png
Tips on Codes
Flow Chart
../_images/1.17_scratch1.png
In this code, you will see 2 pink blocks, turn left and turn right, which are our custom blocks (functions).
../_images/1.17_new_block1.png
How to Make a Block?
Let’s learn how to make a block (function). The block (function) can be used to simplify your program, especially if you perform the same operation multiple times. Putting these operations into a newly declared block can be very convenient for you.
First find My Blocks in the block palette, then select Make a Block.
../_images/1.17_motor41.png
Enter the name of the new block.
../_images/1.17_motor51.png
After writing the function of the new block in the coding area, save it and then you can find the block in the blocks palette.
../_images/1.17_motor61.png
turn left
This is the code inside the turn left block to make the motor rotate counterclockwise.
../_images/1.17_motor121.png
turn right
This is the code inside the turn right block to make the motor rotate clockwise.
../_images/1.17_motor111.png
