4.1.19 AttendanceSystem
Let’s make a simple attendance system. When we scan the card, the Raspberry Pi will record our information and generate a csv file.
../_images/4.1.20components2.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Audio Module and Speaker
LED Matrix Module
MFRC522 Module
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO25
Pin 22
SPIMOSI
Pin 19
12
MOSI
SPIMISO
Pin 19
12
MISO
SPICE0
pin 24
10
CE0
SPICE1
pin 26
11
CE1
SPISCLK
Pin 23
14
SCLK
../_images/4.1.20_schematic.png
Experimental Procedures
Turn on the SPI before starting the experiment, refer to SPI Configuration for details.
The Luma.LED_Matrix and the Spidev and MFRC522 libraries are also needed.
Step 1: Build the circuit.
../_images/atten1.png
Step 2: Run the 2.2.10_write.py file to modify the content of the rfid card.
cd ~/raphael-kit/python
sudo python3 2.2.10_write.py
Step 3: Enter the name (here we use John``as an example) and press ``Enter to confirm, then put the card on the MFRC522 module, wait for “Data writing is complete” to appear and take the card away, or rewrite the message to another card and exit by Ctrl+C.
../_images/write_card.png
Step 4: Get into the folder of code and run.
sudo python3 4.1.19_Attendance_Machine.py
After starting the program, we put the RFID card close to the MFRC522 RFID Module, the Raspberry Pi will send out a voice to greet you and display it on the LED matrix.
We can also find a .csv file that records the time and list in the same directory. Open it with the nano command and you will see the record just now.
sudo nano attendance_sheet.2021.06.29.csv
../_images/atten3.png
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
from tts import TTS
import RPi.GPIO as GPIO
from mfrc522 import SimpleMFRC522
from luma.core.interface.serial import spi, noop
from luma.core.render import canvas
from luma.core.virtual import viewport
from luma.led_matrix.device import max7219
from luma.core.legacy import text
from luma.core.legacy.font import proportional, CP437_FONT, LCD_FONT
serial = spi(port=0, device=1, gpio=noop())
device = max7219(serial, rotate=1)
virtual = viewport(device, width=200, height=400)
reader = SimpleMFRC522()
tts = TTS(engine="espeak")
tts.lang('en-US')
attendance_statistics = {}
def get_time():
    time.time()
    year = str(time.strftime('%Y',time.localtime(time.time())))
    month = str(time.strftime('%m',time.localtime(time.time())))
    day = str(time.strftime('%d',time.localtime(time.time())))
    hour = str(time.strftime('%H',time.localtime(time.time())))
    minute = str(time.strftime('%M',time.localtime(time.time())))
    second = str(time.strftime('%S',time.localtime(time.time())))
    present_time = year + '.' + month + '.' + day + '.' + hour + '.' + minute + '.' + second
    present_date = year + '.' + month + '.' + day
    return present_date, present_time
def main():
        print("Reading...Please place the card...")
        id, name = reader.read()
        print(id,name)
        greeting = name.rstrip() + ", Welcome!"
        present_date, present_time = get_time()
        attendance_statistics[name.rstrip()] = present_time
        tts.say(greeting)
        with open('attendance_sheet.' + present_date + '.csv', 'w') as f:
            [f.write('{0}  {1}\n'.format(key, value)) for key, value in attendance_statistics.items()]
        with canvas(virtual) as draw:
            text(draw, (0, 0), greeting, fill="white", font=proportional(CP437_FONT))
        for offset in range(95):
            virtual.set_position((offset,0))
            time.sleep(0.1)
def destroy():
    GPIO.cleanup()
if __name__ == '__main__':
        main()
        destroy()
Code Explanation
In order to better understand the program, you may need to complete 1.1.6 LED Dot Matrix , 2.2.10 MFRC522 RFID Module and 3.1.4 Text-to-speech first.
def get_time():
        time.time()
Use the get_time() function to get the current timestamp and return two values. Among them, present_date is accurate to the number of days of the current timestamp, and present_time is accurate to the number of seconds of the current timestamp.
The reader.read() function reads the name information, and then creates a greeting. Then an attendance_statistics dictionary is generated, and name.rstrip() and present_time are stored as keys and values.
tts.say(greeting)
Say a greeting through the speaker.
Write the attendance_statistics to the .csv file.
    time.sleep(0.1)
Scroll to display this greeting.
Phenomenon Picture
../_images/attend_system.JPG
