Power Supply ModuleΒΆ
When we need a large current to drive a component, which will severely interfere with the normal work of Raspberry Pi. Therefore, we separately supply power for the component by this module to make it run safely and steadily.
You can just plug it in the breadboard to supply power. It provides a voltage of 3.3V and 5V, and you can connect either via a jumper cap included.
Features and specifications
Input voltage: 6.5 - 12V
Two Independent Channel
Output voltage: 5V, 3.3V (adjustable via jumpers. 0V, 3.3V, and 5V configuration)
Output current: Maximum output current 700mA
Onboard berg male header for GND, 5V, 3.3V output
ON-OFF Switch available.
USB (Type-A) input available.
DC Barrel Jack input available.
Onboard power LED
Dimension: 53mm x 33mm (L x W)
Example
1.3.1 Motor (C Project)
3.1.4 Smart Fan (C Project)
1.3.1 Motor (Python Project)
4.1.10 Smart Fan (Python Project)
1.17 Rotating fan (Scratch Project)
