Check and Install the WiringPi
wiringPi is a C language GPIO library applied to the Raspberry Pi platform and the Raspberry Pi OS installs it by default. It complies with GUN Lv3. The functions in wiringPi are similar to those in the wiring system of Arduino. They enable the users familiar with Arduino to use wiringPi more easily.
wiringPi includes lots of GPIO commands which enable you to control all kinds of interfaces on Raspberry Pi. You can test whether the wiringPi library is installed successfully or not by the following instruction.
gpio -v
_images/image30.png
  • If your Raspberry Pi OS is version 10.31 and above, there will be an error message: wiringPi.h: NO such file or directory.
  • If you are using Raspberry Pi 4B, but the GPIO version is 2.50, it will cause no response after the C language code is running, that is, GPIO pins do not work.
At this time, you need to manually update to version 2.52, the update steps are as follows :
cd /tmp
wget https://project-downloads.drogon.net/wiringpi-latest.deb
sudo dpkg -i wiringpi-latest.deb
Check with:
gpio -v
and make sure it’s version 2.52.
gpio readall
_images/image31.png
For more details about wiringPi, you can refer to WiringPi.
