.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _4.1.6_py_pi5: 4.1.3 Magnetic Induction Alarm System ============================================ Introduction ----------------- When you get a precious vase, you can make a magnetic induction alarm system for it, no matter who moves it, you can hear the alarm in time. Required Components ------------------------------ In this project, we need the following components. .. image:: ../python_pi5/img/4.1.6_magneticalarmsystem_list.png :width: 800 :align: center It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - Raphael Kit - 337 - |link_Raphael_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_gpio_board` - |link_gpio_board_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_buzzer` - |link_passive_buzzer_buy| * - :ref:`cpn_transistor` - |link_transistor_buy| * - :ref:`cpn_reed_switch` - |link_reed_switch_buy| Schematic Diagram ----------------------- ============ ======== ======== === T-Board Name physical wiringPi BCM GPIO17 Pin 11 0 17 GPIO27 Pin 13 2 27 ============ ======== ======== === .. image:: ../python_pi5/img/4.1.6_magneticalarmsystem_schematic.png :align: center Experimental Procedures ------------------------------ **Step 1:** Build the circuit. .. image:: ../python_pi5/img/4.1.6_magneticalarmsystem_circuit.png :width: 800 :align: center **Step 2:** Get into the folder of the code. .. raw:: html .. code-block:: cd ~/raphael-kit/python-pi5 **Step 3:** Run. .. raw:: html .. code-block:: sudo python3 4.1.6_MagneticAlarmSystem_zero.py If the reed switch is affected by the magnet (for example, the reed switch is placed on the base and the magnet is placed in the vase), the object is safe. At this time, the reed switch is in the closed state, and the buzzer is silent. After removing the magnet (such as the vase being stolen), the reed switch is not affected by the magnetic, the switch opens, and the buzzer sounds an alarm. .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python #!/usr/bin/env python3 from gpiozero import Buzzer, Button import time # Initialize the buzzer on GPIO pin 27 buzzer = Buzzer(27) # Initialize the reed switch on GPIO pin 17 with pull-up resistor enabled reed_switch = Button(17, pull_up=True) try: while True: # Check if the reed switch is pressed if reed_switch.is_pressed: # Turn off the buzzer if reed switch is pressed buzzer.off() else: # If reed switch is not pressed, beep the buzzer buzzer.on() time.sleep(0.1) # Buzzer on for 0.1 seconds buzzer.off() time.sleep(0.1) # Buzzer off for 0.1 seconds except KeyboardInterrupt: # Turn off the buzzer when the program is interrupted (e.g., keyboard interrupt) buzzer.off() pass **Code Explanation** #. This imports the necessary classes ``Buzzer`` and ``Button`` from the ``gpiozero`` library, and the ``time`` module from Python's standard library. .. code-block:: python #!/usr/bin/env python3 from gpiozero import Buzzer, Button import time #. The ``Buzzer`` object is linked to GPIO pin 27, and a ``Button`` (acting as a reed switch) is connected to GPIO pin 17 with the ``pull_up=True`` argument, enabling the internal pull-up resistor. .. code-block:: python # Initialize the buzzer on GPIO pin 27 buzzer = Buzzer(27) # Initialize the reed switch on GPIO pin 17 with pull-up resistor enabled reed_switch = Button(17, pull_up=True) #. The ``try`` block contains an infinite loop (``while True``) checking the state of the reed switch. If pressed (``is_pressed``), the buzzer is turned off. Otherwise, the buzzer beeps (0.1 seconds on, 0.1 seconds off). .. code-block:: python try: while True: # Check if the reed switch is pressed if reed_switch.is_pressed: # Turn off the buzzer if reed switch is pressed buzzer.off() else: # If reed switch is not pressed, beep the buzzer buzzer.on() time.sleep(0.1) # Buzzer on for 0.1 seconds buzzer.off() time.sleep(0.1) # Buzzer off for 0.1 seconds #. The ``except`` block handles a KeyboardInterrupt (like a Ctrl+C in the terminal) to turn off the buzzer safely. .. code-block:: python except KeyboardInterrupt: # Turn off the buzzer when the program is interrupted (e.g., keyboard interrupt) buzzer.off() pass
