.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _4.1.11_py_pi5:
4.1.8 Battery Indicator
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
In this project, we will make a battery indicator device that can
visually display the battery level on the LED Bargraph.
.. warning::
Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi.
.. image:: ../python_pi5/img/4.1.11_battery_indicator_list.png
:align: center
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_bar_graph`
* - :ref:`cpn_adc0834`
Schematic Diagram
GPIO17 Pin 11 0 17
GPIO18 Pin 12 1 18
GPIO27 Pin 13 2 27
GPIO25 Pin 22 6 25
GPIO12 Pin 32 26 12
GPIO16 Pin 36 27 16
GPIO20 Pin 38 28 20
GPIO21 Pin 40 29 21
GPIO5 Pin 29 21 5
GPIO6 Pin 31 22 6
GPIO13 Pin 33 23 13
GPIO19 Pin 35 24 19
GPIO26 Pin 37 25 26
.. image:: ../python_pi5/img/4.1.11_battery_indicator_schematic.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../python_pi5/img/4.1.11_battery_indicator_circuit.png
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/raphael-kit/python-pi5
**Step 3:** Run the executable file.
.. raw:: html
.. code-block::
sudo python3 4.1.11_BatteryIndicator_zero.py
After the program runs, give the 3rd pin of ADC0834 and the GND a
lead-out wire separately and then lead them to the two poles of a
battery separately. You can see the corresponding LED on the LED
Bargraph is lit up to display the power level (measuring range: 0-5V).
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
from gpiozero import LED
import spidev
# List of GPIO pins to which LEDs are connected
ledPins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26]
# Initialize LED objects for each pin in the list
leds = [LED(pin) for pin in ledPins]
# Setup SPI for MCP3008
spi = spidev.SpiDev()
spi.open(0, 0) # Open SPI bus 0, device (CE0)
spi.max_speed_hz = 1000000 # Set SPI speed to 1 MHz
def read_adc(channel=0):
Reads analog value from MCP3008 channel (default CH0).
Returns a 10-bit value .
return -1
value = ((r[1] & 0x03) << 8) | r[2]
return value
def LedBarGraph(value):
# Turn off all LEDs
for i in range(10):
leds[i].on()
# Turn on LEDs up to the specified value
for i in range(min(value, 10)):
leds[i].off()
# Main loop to continuously update LED bar graph
analogVal = read_adc(0) # Read from CH0
LedBarGraph(int(analogVal / 102.4))
time.sleep(0.1)
# Turn off all LEDs when program is interrupted
for i in range(10):
leds[i].off()
spi.close()
**Code Explanation**
#. This section imports the necessary libraries. `gpiozero` is used for controlling GPIO pins (specifically LEDs), `spidev` is used to interface with the MCP3008 ADC over SPI, and `time` is used for delays.
import spidev
#. Defines the GPIO pins to which the LEDs are connected and creates a list of `LED` objects. These are used to represent a bar graph.
#. Initializes SPI communication for the MCP3008 ADC on SPI bus 0 using CE0. The speed is set to 1 MHz.
#. Reads a 10-bit analog value (0–1023) from the specified MCP3008 channel. Channel 0 is used by default.
return -1
return value
#. This function turns on all LEDs first (reset state), then turns off a number of LEDs based on the scaled input value. It creates a reverse bar graph effect (more value = fewer LEDs lit).
# Turn off all LEDs
for i in range(10):
leds[i].on()
leds[i].off()
#. Continuously reads the analog value from MCP3008 CH0 and updates the LED bar graph. The analog value is divided by 102.4 to scale it from 0–1023 to a 0–10 LED level.
time.sleep(0.1)
#. Ensures all LEDs are turned off and SPI is closed when the program is interrupted (e.g., by pressing Ctrl+C).
for i in range(10):
leds[i].off()
spi.close()
