.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _4.1.10_py_pi5:
4.1.7 Smart Fan
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
In this project, we will use motors, buttons and thermistors to make a
manual + automatic smart fan whose wind speed is adjustable.
.. image:: ../python_pi5/img/4.1.10_smart_fan_list.png
:width: 800
:align: center
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_power_module`
* - :ref:`cpn_thermistor`
- |link_thermistor_buy|
* - :ref:`cpn_l293d`
* - :ref:`cpn_adc0834`
* - :ref:`cpn_button`
- |link_button_buy|
* - :ref:`cpn_motor`
- |link_motor_buy|
Schematic Diagram
GPIO17 Pin 11 0 17
GPIO18 Pin 12 1 18
GPIO27 Pin 13 2 27
GPIO22 Pin 15 3 22
GPIO5 Pin 29 21 5
GPIO6 Pin 31 22 6
GPIO13 Pin 33 23 13
.. image:: ../python_pi5/img/4.1.10_smart_fan_schematic.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../python_pi5/img/4.1.10_smart_fan_circuit.png
.. note::
The power module can apply a 9V battery with the 9V Battery
Buckle in the kit. Insert the jumper cap of the power module into the 5V
bus strips of the breadboard.
.. image:: ../python_pi5/img/4.1.10_smart_fan_battery.jpeg
:align: center
**Step 2**: Get into the folder of the code.
.. raw:: html
.. code-block::
cd ~/raphael-kit/python-pi5
**Step 3**: Run.
.. raw:: html
.. code-block::
sudo python3 4.1.10_SmartFan_zero.py
As the code runs, start the fan by pressing the button. Every time you
press, 1 speed grade is adjusted up or down. There are **5** kinds of
speed grades: **0~4**. When set to the 4\ :sup:`th` speed grade and you
press the button, the fan stops working with a **0** wind speed.
Once the temperature goes up or down for more than 2℃, the speed
automatically gets 1-grade faster or slower.
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
from gpiozero import Motor, Button
from time import sleep
import ADC0834
import math
# Initialize GPIO pins for the button and motor control
BtnPin = Button(22)
motor = Motor(forward=5, backward=6, enable=13)
# Initialize the ADC0834 module for temperature sensing
ADC0834.setup()
# Initialize variables to track the motor speed level and temperatures
level = 0
currentTemp = 0
markTemp = 0
def temperature():
Reads and calculates the current temperature from the sensor.
Returns:
float: The current temperature in Celsius.
# Read analog value from the ADC0834 module
# Convert analog value to voltage and then to resistance
Vr = 5 * float(analogVal) / 255
Rt = 10000 * Vr / (5 - Vr)
# Calculate temperature in Celsius
temp = 1 / (((math.log(Rt / 10000)) / 3950) + (1 / (273.15 + 25)))
Cel = temp - 273.15
return Cel
def motor_run(level):
Adjusts the motor speed based on the specified level.
Args:
level (int): Desired motor speed level.
Returns:
int: Adjusted motor speed level.
# Stop the motor if the level is 0
if level == 0:
motor.stop()
return 0
# Cap the level at 4 for maximum speed
if level >= 4:
level = 4
# Set the motor speed
motor.forward(speed=float(level / 4))
return level
def changeLevel():
Changes the motor speed level when the button is pressed and updates the reference temperature.
global level, currentTemp, markTemp
print("Button pressed")
# Cycle through levels 0-4
level = (level + 1) % 5
# Update the reference temperature
markTemp = currentTemp
# Bind the button press event to changeLevel function
BtnPin.when_pressed = changeLevel
def main():
Main function to continuously monitor and respond to temperature changes.
# Set initial reference temperature
markTemp = temperature()
# Continuously read current temperature
currentTemp = temperature()
# Adjust motor level based on temperature difference
if level != 0:
if currentTemp - markTemp <= -2:
level -= 1
elif currentTemp - markTemp >= 2:
if level < 4:
level += 1
# Run the motor at the adjusted level
level = motor_run(level)
# Run the main function and handle KeyboardInterrupt
main()
# Stop the motor when the script is interrupted
motor.stop()
Code Explanation
#. Imports classes for managing a motor and a button, and the sleep function for introducing pauses. Additionally, it imports the ADC0834 library for temperature sensing and the math library for mathematical calculations.
import ADC0834
import math
#. Sets up the button on GPIO pin 22 and configures the motor with specific GPIO pins for control. Initializes the ADC0834 module for temperature measurement. Also, initializes variables to monitor the motor speed level and temperatures.
BtnPin = Button(22)
ADC0834.setup()
level = 0
currentTemp = 0
markTemp = 0
#. Defines a function to read and calculate the temperature from the sensor, converting the readout to Celsius.
def temperature():
Returns:
Cel = temp - 273.15
return Cel
#. Introduces a function to adjust the motor speed according to the specified level.
Args:
Returns:
if level == 0:
motor.stop()
return 0
if level >= 4:
level = 4
return level
#. Implements a function to change the motor speed level manually using a button, and binds this function to the button's press event.
def changeLevel():
#. The main function, designed to continually adjust the motor speed in response to temperature fluctuations, remains to be implemented.
def main():
if level != 0:
level -= 1
if level < 4:
level += 1
#. Runs the main function and ensures the motor stops if the script is interrupted.
main()
motor.stop()
