.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _3.1.2_py_pi5: 3.1.2 Video Module ===================== Introduction ----------------- In addition to taking photos, the Camera Module can also be used to record videos. Required Components ------------------------------ In this project, we need the following components. .. image:: ../python_pi5/img/3.3.2_photograph_list.png :width: 800 It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - Raphael Kit - 337 - |link_Raphael_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_camera_module` - |link_camera_buy| Experimental Procedures ------------------------------ **Step 1:** Go into the Raspberry Pi Desktop. You may need a screen for a better experience, refer to: `Connect your Raspberry Pi `_. Or access the Raspberry Pi desktop remotely, for a detailed tutorial please refer to :ref:`remote_desktop`. **Step 2:** Open a Terminal and get into the folder of the code. .. code-block:: cd ~/raphael-kit/python-pi5 **Step 3:** Run. .. code-block:: sudo python3 3.1.2_VideoModule_zero.py Run the code to start recording. Press ``Ctrl+C`` to end the recording. Name the video ``my_video.h264`` and store it in the ``~`` directory. .. note:: You can also open ``3.1.2_PhotographModule_zero.py`` in the ``~/raphael-kit/python-pi5`` path with a Python IDE, click Run button to run, and stop the code with Stop button. If you want to send photos to your PC, please refer to :ref:`filezilla`. .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. code-block:: python #!/usr/bin/env python3 import time from picamera2 import Picamera2, Preview from picamera2.encoders import H264Encoder from picamera2.outputs import FfmpegOutput import os # Get the current user's login name user = os.getlogin() # Get the path to the user's home directory user_home = os.path.expanduser(f'~{user}') # Create a Picamera2 instance camera = Picamera2() # Retrieve the default preview configuration preview_config = camera.preview_configuration try: # Configure preview size and format preview_config.size = (800, 600) preview_config.format = 'XRGB8888' # Start the camera preview in QTGL mode camera.start_preview(Preview.QTGL) # Define video configuration with size, frame rate, and buffer count conf = {'size': (800, 600)} controls = {'FrameRate': 40} config = camera.create_video_configuration(main=conf, controls=controls, buffer_count=12) # Create a video encoder with a specified bitrate encoder = H264Encoder(bitrate=10000000) # Define output file for the video output = FfmpegOutput(f'{user_home}/my_video.mp4') # Configure and start recording camera.configure(config) camera.start_recording(encoder, output) # Record for 10 seconds time.sleep(10) # Stop the recording camera.stop_recording() except KeyboardInterrupt: # Stop the camera preview if a KeyboardInterrupt (e.g., Ctrl+C) occurs camera.stop_preview() pass **Code Explanation** #. Imports necessary libraries and classes. The ``picamera2`` library is used for camera control, ``H264Encoder`` for video encoding, and ``FfmpegOutput`` for defining the video output file. .. code-block:: python #!/usr/bin/env python3 import time from picamera2 import Picamera2, Preview from picamera2.encoders import H264Encoder from picamera2.outputs import FfmpegOutput import os #. Retrieves the current user's login name and the path to their home directory. .. code-block:: python # Get the current user's login name user = os.getlogin() # Get the path to the user's home directory user_home = os.path.expanduser(f'~{user}') #. Creates an instance of the ``Picamera2`` class and retrieves the default preview configuration. .. code-block:: python # Create a Picamera2 instance camera = Picamera2() # Retrieve the default preview configuration preview_config = camera.preview_configuration #. Sets the size and format of the camera preview. The size is set to 800x600 pixels, and the format is set to ``XRGB8888``. .. code-block:: python try: # Configure preview size and format preview_config.size = (800, 600) preview_config.format = 'XRGB8888' #. Starts the camera preview in QTGL mode, a graphical preview mode. .. code-block:: python try: ... # Start the camera preview in QTGL mode camera.start_preview(Preview.QTGL) ... #. Defines the video configuration with a frame size of 800x600 pixels and a frame rate of 40 frames per second. .. code-block:: python try: ... # Define video configuration with size, frame rate, and buffer count conf = {'size': (800, 600)} controls = {'FrameRate': 40} config = camera.create_video_configuration(main=conf, controls=controls, buffer_count=12) ... #. Creates a video encoder with a specified bitrate of 10 Mbps, using the H.264 encoding format. Sets up the output file path for the video, saving it as ``my_video.mp4`` in the user's home directory. .. code-block:: python try: ... # Create a video encoder with a specified bitrate encoder = H264Encoder(bitrate=10000000) # Define output file for the video output = FfmpegOutput(f'{user_home}/my_video.mp4') ... #. Configures the camera with the defined video settings, starts recording using the specified encoder and output file, records for 10 seconds, and then stops the recording. .. code-block:: python try: ... # Configure and start recording camera.configure(config) camera.start_recording(encoder, output) # Record for 10 seconds time.sleep(10) # Stop the recording camera.stop_recording() #. This block of code handles a KeyboardInterrupt (such as Ctrl+C) by stopping the camera preview. The ``pass`` statement is used to handle the exception without doing anything else. .. code-block:: python except KeyboardInterrupt: # Stop the camera preview if a KeyboardInterrupt (e.g., Ctrl+C) occurs camera.stop_preview() pass
