.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _3.1.1_py_pi5: 3.1.1 Photograph Module ========================== Introduction ----------------- In this kit, equipped with a camera module, let's try to take a picture with Raspberry Pi. Required Components ------------------------------ In this project, we need the following components. .. image:: ../python_pi5/img/3.3.1_photograph_list.png :width: 800 It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - Raphael Kit - 337 - |link_Raphael_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_camera_module` - |link_camera_buy| Experimental Procedures ------------------------------ **Step 1:** Go into the Raspberry Pi Desktop. You may need a screen for a better experience, refer to: `Connect your Raspberry Pi `_. Or access the Raspberry Pi desktop remotely, for a detailed tutorial please refer to :ref:`remote_desktop`. **Step 2:** Open a Terminal and get into the folder of the code. .. code-block:: cd ~/raphael-kit/python-pi5 **Step 3:** Run. .. code-block:: sudo python3 3.1.1_PhotographModule_zero.py After the code runs, the camera will take a photo. Now you can see the photo named ``my_photo.jpg`` in the ``~`` directory. .. note:: You can also open ``3.1.1_PhotographModule.py`` in the ``~/raphael-kit/python-pi5/`` path with a Python IDE, click Run button to run, and stop the code with Stop button. If you want to download the photo to your PC, please refer to :ref:`filezilla`. .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. code-block:: python #!/usr/bin/env python3 from picamera2 import Picamera2, Preview import os # Get the current user's login name user = os.getlogin() # Get the path to the user's home directory user_home = os.path.expanduser(f'~{user}') # Create a Picamera2 instance camera = Picamera2() # Retrieve the default preview configuration preview_config = camera.preview_configuration try: # Set preview size and format preview_config.size = (800, 600) preview_config.format = 'XRGB8888' # Start the camera preview in QTGL mode camera.start_preview(Preview.QTGL) # Start the camera camera.start() # Capture and save a photo to the user's home directory camera.capture_file(f'{user_home}/my_photo.jpg') except KeyboardInterrupt: # Stop the camera preview if a KeyboardInterrupt (e.g., Ctrl+C) occurs camera.stop_preview() pass **Code Explanation** #. Imports the ``Picamera2`` and ``Preview`` classes from the picamera2 library, and the ``os`` module for operating system interactions. .. code-block:: python #!/usr/bin/env python3 from picamera2 import Picamera2, Preview import os #. Retrieves the current user's login name and the path to their home directory. .. code-block:: python # Get the current user's login name user = os.getlogin() # Get the path to the user's home directory user_home = os.path.expanduser(f'~{user}') #. Creates an instance of the ``Picamera2`` class and retrieves the default preview configuration. .. code-block:: python # Create a Picamera2 instance camera = Picamera2() # Retrieve the default preview configuration preview_config = camera.preview_configuration #. Sets the size and format of the camera preview. The size is set to 800x600 pixels, and the format is set to ``XRGB8888``. .. code-block:: python try: # Set preview size and format preview_config.size = (800, 600) preview_config.format = 'XRGB8888' ... #. Starts the camera preview in QTGL mode, which is a method for displaying the preview, and then starts the camera itself. .. code-block:: python try: ... # Start the camera preview in QTGL mode camera.start_preview(Preview.QTGL) # Start the camera camera.start() ... #. Capture an image from the camera, storing it in ``~/``. .. code-block:: python try: ... # Capture and save a photo to the user's home directory camera.capture_file(f'{user_home}/my_photo.jpg') .. note:: You can use ``camera.capture()`` function and ``for`` loop together to achieve continuous shooting. And use the ``delay`` function to adjust the time interval for taking pictures. .. code-block:: python for i in 5: camera.capture(f'{user_home}/my_photo%s.jpg' % i) #. This block of code handles a KeyboardInterrupt (such as Ctrl+C) by stopping the camera preview. The ``pass`` statement is used to handle the exception without doing anything else. .. code-block:: python except KeyboardInterrupt: # Stop the camera preview if a KeyboardInterrupt (e.g., Ctrl+C) occurs camera.stop_preview() pass
