.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.2.2_py_pi5:
2.2.2 Thermistor
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
Just like photoresistor can sense light, thermistor is a temperature
sensitive electronic device that can be used for realizing functions of
temperature control, such as making a heat alarm.
.. image:: ../python_pi5/img/2.2.2_thermistor_list.png
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_thermistor`
- |link_thermistor_buy|
* - :ref:`cpn_adc0834`
Schematic Diagram
.. image:: ../python_pi5/img/2.2.2_thermistor_schematic_1.png
.. image:: ../python_pi5/img/2.2.2_thermistor_schematic_2.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../python_pi5/img/2.2.2_thermistor_circuit.png
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/raphael-kit/python-pi5
**Step 3:** Run the executable file
.. raw:: html
.. code-block::
sudo python3 2.2.2_Thermistor_zero.py
With the code run, the thermistor detects ambient temperature which will
be printed on the screen once it finishes the program calculation.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
# -*- coding: utf-8 -*-
import ADC0834
import math
# Initialize the ADC0834 module
ADC0834.setup()
# Run the process in a try-except block
# Read the analog value from the sensor
# Convert the analog value to a voltage
Vr = 5 * float(analogVal) / 255
# Calculate the resistance of the thermistor
Rt = 10000 * Vr / (5 - Vr)
# Calculate the temperature in Kelvin
temp = 1 / (((math.log(Rt / 10000)) / 3950) + (1 / (273.15 + 25)))
# Convert Kelvin to Celsius
Cel = temp - 273.15
# Convert Celsius to Fahrenheit
Fah = Cel * 1.8 + 32
# Print the temperature in both Celsius and Fahrenheit
print('Celsius: %.2f C Fahrenheit: %.2f F' % (Cel, Fah))
# Wait for 0.2 seconds before the next read
time.sleep(0.2)
# Handle KeyboardInterrupt for graceful termination
# Clean up ADC0834 resources
ADC0834.destroy()
**Code Explanation**
#. This section imports the ADC0834 library for analog-to-digital conversion, the time library for implementing delays, and the math library for conducting mathematical operations.
import ADC0834
import math
#. Initializes the ADC0834 module to enable reading of analog values.
ADC0834.setup()
#. Implements an infinite loop for continuous data reading. The loop reads the analog value from a thermistor, converts this value to voltage, calculates the thermistor's resistance, and then translates this resistance into temperature measurements in Kelvin, Celsius, and Fahrenheit. It also outputs the temperature readings in Celsius and Fahrenheit, pausing for 0.2 seconds between each reading.
Cel = temp - 273.15
time.sleep(0.2)
#. Catches a KeyboardInterrupt exception to gracefully terminate the program and includes clean-up instructions for the ADC0834 resources upon termination.
ADC0834.destroy()
