.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.2.1_py_pi5_mcp3008:
2.2.1 Photoresistor(MCP3008)
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
Photoresistor is a commonly used component of ambient light intensity in
life. It helps the controller to recognize day and night and realize
light control functions such as night lamp. This project is very similar
to potentiometer, and you might think it changing the voltage to sensing
light.
.. image:: ../python_pi5/img/list2_2.2.1_photoresistor.png
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_led`
- |link_led_buy|
* - :ref:`cpn_mcp3008`
* - :ref:`cpn_photoresistor`
- |link_photoresistor_buy|
Schematic Diagram
.. .. image:: ../python_pi5/img/2.2.1_photoresistor_schematic_1.png
.. list-table::
:widths: 30 30 30 30
:header-rows: 1
* - T-Board Name
- physical
- WiringPi
- BCM
* - SPICE0
- pin24
- 10
- 8
* - SPIMOSI
- pin19
- 12
- 10
* - SPIMISO
- pin21
- 13
- 9
* - SPISCLK
- pin23
- 14
- 11
* - GPIO22
- pin15
- 3
- 22
.. image:: ../python_pi5/img/schematic_2.2.1_photoresistor_mcp3008.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../python_pi5/img/july24_2.2.1_photoresistor_mcp3008.png
**Step 2:** Set up the SPI interface and install the ``spidev`` library (see :ref:`spi_configuration` for detailed instructions). If you have already completed these steps, you can skip this.
**Step 3:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/raphael-kit/python-pi5
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
sudo python3 2.2.1-2_Photoresistor_zero.py
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
import spidev
from gpiozero import PWMLED
# Initialize a PWM LED on GPIO pin 22
led = PWMLED(22)
# Initialize SPI communication (Bus 0, CE0 -> GPIO8)
spi = spidev.SpiDev()
spi.open(0, 0) # Bus 0, CS0
spi.max_speed_hz = 1000000 # 1 MHz
# Function to read from MCP3008 channel (0–7)
def read_adc(channel):
Read analog value from MCP3008 (0–1023)
return -1
# MCP3008 protocol: Start bit, Single-ended mode, Channel (3 bits), filler
value = ((r[1] & 3) << 8) | r[2]
return value
# Define a function for mapping values from one range to another
# Main loop for reading ADC value and controlling LED brightness
def loop():
# Read analog value from channel 0 of MCP3008
analogVal = read_adc(0)
print('value = %d' % analogVal)
# Map 0–1023 to PWM range 0.0–1.0
led.value = analogVal / 1023.0
# Wait for 0.2 seconds
time.sleep(0.2)
# Run the main loop and handle KeyboardInterrupt for graceful shutdown
loop()
led.value = 0 # Turn off LED before exiting
**Code Explanation**
#. This segment imports the ``PWMLED`` class from the ``gpiozero`` library for controlling PWM LEDs, ``spidev`` for SPI communication with MCP3008, and ``time`` for executing sleep/delay operations.
import spidev
#. Initializes a PWM LED connected to GPIO pin 22, and sets up the SPI interface for MCP3008 (Bus 0, CE0). The SPI clock speed is set to 1 MHz.
led = PWMLED(22)
#. Defines a function to read from a specific MCP3008 ADC channel. It sends a 3-byte command over SPI and extracts a 10-bit value (0–1023) from the response.
return -1
return value
#. Defines a helper function ``MAP()`` that maps a number from one range to another. This is useful for converting raw ADC values into a suitable PWM range.
#. This section implements a loop that repeatedly reads an analog value from channel 0 of the MCP3008, maps it to a PWM brightness value (0.0–1.0), and applies it to the LED. The loop pauses for 0.2 seconds between readings.
def loop():
time.sleep(0.2)
#. Executes the loop and gracefully handles ``KeyboardInterrupt``. When the user stops the program (Ctrl+C), the LED is turned off before exiting.
loop()
led.value = 0
