.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
π Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.1.7_py_pi5_mcp3008:
2.1.7 Potentiometer(MCP3008)
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
The ADC function is used to convert analog signals into digital values.
In this experiment, we use the MCP3008 ADC chip to perform this conversion.
A potentiometer is used to generate a variable voltage, which changes the physical quantity.
The MCP3008 then converts this analog voltage into a digital value that can be read and processed by the Raspberry Pi.
.. image:: ../python_pi5/img/list2_2.1.4_potentiometer.png
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_led`
- |link_led_buy|
* - :ref:`cpn_potentiometer`
- |link_potentiometer_buy|
* - :ref:`cpn_mcp3008`
Schematic Diagram
.. list-table::
:widths: 30 30 30 30
:header-rows: 1
* - T-Board Name
- physical
- WiringPi
- BCM
* - SPICE0
- pin24
- 10
- 8
* - SPIMOSI
- pin19
- 12
- 10
* - SPIMISO
- pin21
- 13
- 9
* - SPISCLK
- pin23
- 14
- 11
* - GPIO22
- pin15
- 3
- 22
.. image:: ../python_pi5/img/schematic_2.1.7_potentiometer_mcp3008.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../python_pi5/img/july24_2.1.7_potentiometer_mcp3008.png
.. note::
Please place the chip by referring to the corresponding position
depicted in the picture. Note that the grooves on the chip should be on
the left when it is placed.
**Step 2:** Set up the SPI interface and install the ``spidev`` library (see :ref:`spi_configuration` for detailed instructions). If you have already completed these steps, you can skip this.
**Step 3:** Open the code file
.. raw:: html
.. code-block::
cd ~/raphael-kit/python-pi5
**Step 4:** Run.
.. raw:: html
.. code-block::
sudo python3 2.1.7-2_Potentiometer_zero.py
After the code runs, rotate the knob on the potentiometer, the intensity
of LED will change accordingly.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
import spidev
from gpiozero import PWMLED
# Initialize PWM LED on GPIO22
led = PWMLED(22)
# Initialize SPI
spi = spidev.SpiDev()
spi.open(0, 0) # Bus 0, CS0 (CE0)
spi.max_speed_hz = 1000000
def read_adc(channel):
Read analog value from MCP3008
:param channel: ADC channel (0-7)
:return: 10-bit integer (0-1023)
return -1
# MCP3008 protocol
value = ((adc[1] & 3) << 8) | adc[2]
return value
Map a value from one range to another
# Read from MCP3008 channel 0
res = read_adc(0)
print('res = %d' % res)
# Map 0β1023 to 0β100%
R_val = MAP(res, 0, 1023, 0, 100)
# Set LED brightness
led.value = R_val / 100.0
time.sleep(0.2)
led.value = 0 # Turn off the LED
**Code Explanation**
#. ``gpiozero`` for PWM LED control, ``spidev`` for SPI communication with MCP3008, and ``time`` for implementing delays.
import spidev
#. Initialize a PWMLED object connected to GPIO pin 22 and configure SPI communication (Bus 0, CE0) with MCP3008.
led = PWMLED(22)
# Initialize SPI
#. Define a function named ``read_adc`` to communicate with MCP3008 and read analog values from the specified channel (0β7).
return -1
return value
#. Define a function named ``MAP`` to convert one range of values to another, useful for mapping ADC values to appropriate LED brightness levels.
#. Continuously read the ADC value in a loop, mapping the 10-bit ADC value (0β1023) to a brightness level (0β100) for the LED. Adjust the LEDβs brightness accordingly. Wait 0.2 seconds between each read.
res = read_adc(0)
time.sleep(0.2)
