.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
π Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.1.6_py_pi5:
2.1.6 Rotary Encoder Module
In this project, you will learn about Rotary Encoder. A rotary encoder is
an electronic switch with a set of regular pulses in strictly timing
sequence. When used with IC, it can achieve increment, decrement, page
turning and other operations such as mouse scrolling, menu selection,
and so on.
.. image:: ../python_pi5/img/2.1.6_rotary_encoder_list.png
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_rotary_encoder`
- |link_rotary_encoder_buy|
Schematic Diagram
.. image:: ../python_pi5/img/2.1.6_rotary_encoder_schematic.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../python_pi5/img/2.1.6_rotary_encoder_circuit.png
In this example, we can connect the Rotary Encoder pin directly to the
Raspberry Pi using a breadboard and 40-pin Cable, connect the GND of the Rotary
Encoder to GND, γ+γto 5V, SW to digital GPIO27, DT to digital GPIO18, and CLK to digital GPIO
17.
**Step 2:** Open the code file.
.. raw:: html
.. code-block::
cd ~/raphael-kit/python-pi5
**Step 3:** Run.
.. raw:: html
.. code-block::
sudo python3 2.1.6_RotaryEncoder_zero.py
You will see the count on the shell. When you turn the rotary encoder clockwise, the count is increased; when turn it counterclockwise, the count is decreased. If you press the switch on the rotary encoder, the readings will return to zero.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
from gpiozero import RotaryEncoder, Button
from time import sleep
# Initialize the rotary encoder and button
encoder = RotaryEncoder(a=17, b=18) # Rotary Encoder connected to GPIO pins 17 (CLK) and 18 (DT)
button = Button(27) # Button connected to GPIO pin 27
global_counter = 0 # Track the rotary encoder's position
def rotary_change():
""" Update the global counter based on the rotary encoder's rotation. """
global global_counter
global_counter += encoder.steps # Adjust counter based on encoder steps
encoder.steps = 0 # Reset encoder steps after updating counter
print('Global Counter =', global_counter) # Display current counter value
def reset_counter():
""" Reset the global counter to zero when the button is pressed. """
global_counter = 0 # Reset the counter
print('Counter reset') # Indicate counter reset
# Assign the reset_counter function to button press event
button.when_pressed = reset_counter
# Monitor rotary encoder continuously and process changes
rotary_change() # Handle rotary encoder changes
sleep(0.1) # Short delay to reduce CPU load
# Gracefully handle a keyboard interrupt (Ctrl+C)
**Code Analysis**
#. Imports the ``RotaryEncoder`` and ``Button`` classes from the ``gpiozero`` library, and the ``sleep`` function for delays.
#. Initializes the rotary encoder with GPIO pins 17 and 18, and a button on GPIO pin 27.
#. Declares a global variable ``global_counter`` to track the position of the rotary encoder.
#. Defines a function ``rotary_change`` to update the global counter based on the rotary encoder's rotation.
#. Defines a function ``reset_counter`` to reset the global counter to zero when the button is pressed.
#. Assigns the ``reset_counter`` function to be called when the button is pressed.
#. In a continuous loop, the script calls ``rotary_change`` to handle rotary encoder changes and introduces a short delay to reduce CPU load. Uses a try-except block to handle KeyboardInterrupts gracefully.
