.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _2.1.4_py_pi5: 2.1.4 Slide Switch ================== Introduction ------------ In this project, we will learn how to use a slide switch. Usually,the slide switch is soldered on PCB as a power switch, but here we need to insert it into the breadboard, thus it may not be tightened. And we use it on the breadboard to show its function. Required Components ------------------------------ In this project, we need the following components. .. image:: ../python_pi5/img/2.1.4_slide_switch_list.png It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - Raphael Kit - 337 - |link_Raphael_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_gpio_board` - |link_gpio_board_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_led` - |link_led_buy| * - :ref:`cpn_slide_switch` - |link_slide_switch_buy| * - :ref:`cpn_capacitor` - |link_capacitor_buy| Schematic Diagram ----------------- Connect the middle pin of the Slide Switch to GPIO17, and two LEDs to pin GPIO22 and GPIO27 respectively. Then when you pull the slide, you can see the two LEDs light up alternately. .. image:: ../python_pi5/img/2.1.4_slide_switch_schematic_1.png .. image:: ../python_pi5/img/2.1.4_slide_switch_schematic_2.png Experimental Procedures ----------------------- **Step 1:** Build the circuit. .. image:: ../python_pi5/img/2.1.4_slide_switch_circuit.png **Step 2**: Get into the folder of the code. .. raw:: html .. code-block:: cd ~/raphael-kit/python-pi5 **Step 3**: Run. .. raw:: html .. code-block:: sudo python3 2.1.4_Slider_zero.py While the code is running, get the switch connected to the left, then the yellow LED lights up; to the right, the red light turns on. .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python #!/usr/bin/env python3 from gpiozero import LED, Button # Import LED and Button classes for GPIO control from time import sleep # Import sleep function for adding delays # Initialize the micro switch on GPIO pin 17 with the pull-up resistor disabled micro_switch = Button(17, pull_up=False) # Initialize LED1 on GPIO pin 22 led1 = LED(22) # Initialize LED2 on GPIO pin 27 led2 = LED(27) try: # Main loop to control LED states based on the micro switch's state while True: if micro_switch.is_pressed: # Check if the micro switch is pressed print(' LED1 ON ') # Print status message led1.on() # Turn on LED1 led2.off() # Turn off LED2 else: # If the micro switch is not pressed print(' LED2 ON ') # Print status message led1.off() # Turn off LED1 led2.on() # Turn on LED2 sleep(0.5) # Wait for 0.5 seconds before rechecking the switch state except KeyboardInterrupt: # Handle a keyboard interrupt (Ctrl+C) for a clean exit from the loop pass **Code Explanation** #. This line sets the script to run with Python 3. It imports ``LED`` and ``Button`` from ``gpiozero`` for controlling GPIO devices, and ``sleep`` from ``time`` for delays. .. code-block:: python #!/usr/bin/env python3 from gpiozero import LED, Button # Import LED and Button classes for GPIO control from time import sleep # Import sleep function for adding delays #. Initializes a micro switch connected to GPIO pin 17 with the pull-up resistor disabled, and two LEDs connected to GPIO pins 22 and 27. .. code-block:: python # Initialize the micro switch on GPIO pin 17 with the pull-up resistor disabled micro_switch = Button(17, pull_up=False) # Initialize LED1 on GPIO pin 22 led1 = LED(22) # Initialize LED2 on GPIO pin 27 led2 = LED(27) #. The main loop checks the state of the micro switch. If pressed, LED1 turns on and LED2 off; if not pressed, LED1 off and LED2 on. The loop repeats every 0.5 seconds. Catches a KeyboardInterrupt (like Ctrl+C) to allow for graceful script termination. .. code-block:: python try: # Main loop to control LED states based on the micro switch's state while True: if micro_switch.is_pressed: # Check if the micro switch is pressed print(' LED1 ON ') # Print status message led1.on() # Turn on LED1 led2.off() # Turn off LED2 else: # If the micro switch is not pressed print(' LED2 ON ') # Print status message led1.off() # Turn off LED1 led2.on() # Turn on LED2 sleep(0.5) # Wait for 0.5 seconds before rechecking the switch state except KeyboardInterrupt: # Handle a keyboard interrupt (Ctrl+C) for a clean exit from the loop pass
