.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _1.2.2_py_pi5: 1.2.2 Passive Buzzer ===================== Introduction ------------ In this project, we will learn how to make a passive buzzer play music. Required Components ------------------------------ In this project, we need the following components. .. image:: ../python_pi5/img/1.2.2_passive_buzzer_list.png It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - Raphael Kit - 337 - |link_Raphael_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_gpio_board` - |link_gpio_board_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_buzzer` - |link_passive_buzzer_buy| * - :ref:`cpn_transistor` - |link_transistor_buy| Schematic Diagram ----------------- In this experiment, a passive buzzer, a NPN transistor and a 1k resistor are used between the base of the transistor and GPIO to protect the transistor. When GPIO17 is given different frequencies, the passive buzzer will emit different sounds; in this way, the buzzer plays music. ============ ======== ======== === T-Board Name physical wiringPi BCM GPIO17 Pin 11 0 17 ============ ======== ======== === .. image:: ../python_pi5/img/1.2.2_passive_buzzer_schematic.png Experimental Procedures ----------------------- **Step 1**: Build the circuit. (The Passive buzzer with green circuit board on the back.) .. image:: ../python_pi5/img/1.2.2_PassiveBuzzer_circuit.png **Step 2: Change directory.** .. raw:: html .. code-block:: cd ~/raphael-kit/python-pi5 **Step 3: Run.** .. raw:: html .. code-block:: sudo python3 1.2.2_PassiveBuzzer_zero.py The code run, the buzzer plays a piece of music. .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python #!/usr/bin/env python3 from gpiozero import TonalBuzzer from time import sleep # Initialize a TonalBuzzer connected to GPIO pin 17 tb = TonalBuzzer(17) # Update this pin number based on your setup def play(tune): """ Play a musical tune using the buzzer. :param tune: List of tuples (note, duration), where each tuple represents a note and its duration. """ for note, duration in tune: print(note) # Output the current note being played tb.play(note) # Play the note on the buzzer sleep(float(duration)) # Delay for the duration of the note tb.stop() # Stop playing after the tune is complete # Define a musical tune as a sequence of notes and durations tune = [('C#4', 0.2), ('D4', 0.2), (None, 0.2), ('Eb4', 0.2), ('E4', 0.2), (None, 0.6), ('F#4', 0.2), ('G4', 0.2), (None, 0.6), ('Eb4', 0.2), ('E4', 0.2), (None, 0.2), ('F#4', 0.2), ('G4', 0.2), (None, 0.2), ('C4', 0.2), ('B4', 0.2), (None, 0.2), ('F#4', 0.2), ('G4', 0.2), (None, 0.2), ('B4', 0.2), ('Bb4', 0.5), (None, 0.6), ('A4', 0.2), ('G4', 0.2), ('E4', 0.2), ('D4', 0.2), ('E4', 0.2)] try: play(tune) # Execute the play function to start playing the tune except KeyboardInterrupt: # Handle KeyboardInterrupt for graceful termination pass **Code Explanation** #. These lines import the ``TonalBuzzer`` class from the ``gpiozero`` library for buzzer control and the ``sleep`` function from the ``time`` module for creating delays. .. code-block:: python #!/usr/bin/env python3 from gpiozero import TonalBuzzer from time import sleep #. This line initializes a ``TonalBuzzer`` object on GPIO pin 17. .. code-block:: python # Initialize a TonalBuzzer connected to GPIO pin 17 tb = TonalBuzzer(17) # Update this pin number based on your setup #. The ``play`` function iterates over a list of tuples representing musical notes and their durations. Each note is played for its specified duration, and the buzzer stops after completing the tune. .. code-block:: python def play(tune): """ Play a musical tune using the buzzer. :param tune: List of tuples (note, duration), where each tuple represents a note and its duration. """ for note, duration in tune: print(note) # Output the current note being played tb.play(note) # Play the note on the buzzer sleep(float(duration)) # Delay for the duration of the note tb.stop() # Stop playing after the tune is complete #. The tune is defined as a sequence of notes (frequency) and durations (seconds). .. code-block:: python # Define a musical tune as a sequence of notes and durations tune = [('C#4', 0.2), ('D4', 0.2), (None, 0.2), ('Eb4', 0.2), ('E4', 0.2), (None, 0.6), ('F#4', 0.2), ('G4', 0.2), (None, 0.6), ('Eb4', 0.2), ('E4', 0.2), (None, 0.2), ('F#4', 0.2), ('G4', 0.2), (None, 0.2), ('C4', 0.2), ('B4', 0.2), (None, 0.2), ('F#4', 0.2), ('G4', 0.2), (None, 0.2), ('B4', 0.2), ('Bb4', 0.5), (None, 0.6), ('A4', 0.2), ('G4', 0.2), ('E4', 0.2), ('D4', 0.2), ('E4', 0.2)] #. The ``play(tune)`` function is called inside a ``try`` block. A ``KeyboardInterrupt`` (like Ctrl+C) will stop the program gracefully. .. code-block:: python try: play(tune) # Execute the play function to start playing the tune except KeyboardInterrupt: # Handle KeyboardInterrupt for graceful termination pass
