.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _1.1.4_py_pi5:
1.1.4 7-segment Display
Let's try to drive a 7-segment display to show a figure from 0 to 9 and
A to F.
.. image:: ../python_pi5/img/1.1.4_7_segment_list.png
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_7_segment`
- |link_7segment_buy|
* - :ref:`cpn_74hc595`
- |link_74hc595_buy|
Schematic Diagram
Connect pin ST_CP of 74HC595 to Raspberry Pi GPIO18, SH_CP to GPIO27, DS
to GPIO17, parallel output ports to 8 segments of the LED segment
display.
Input data in DS pin to shift register when SH_CP (the clock
input of the shift register) is at the rising edge, and to the memory
register when ST_CP (the clock input of the memory) is at the rising
edge.
Then you can control the states of SH_CP and ST_CP via the
Raspberry Pi GPIOs to transform serial data input into parallel data
output so as to save Raspberry Pi GPIOs and drive the display.
T-Board Name physical BCM
GPIO17 Pin 11 17
GPIO18 Pin 12 18
GPIO27 Pin 13 27
.. image:: ../python_pi5/img/1.1.4_7_segment_schematic.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../python_pi5/img/1.1.4_7-Segment_circuit.png
**Step 2:** Get into the folder of the code.
.. raw:: html
.. code-block::
cd ~/raphael-kit/python-pi5
**Step 3:** Run.
.. raw:: html
.. code-block::
sudo python3 1.1.4_7-Segment_zero.py
After the code runs, you'll see the 7-segment display display 0-9, A-F.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python-pi5``. After modifying the code, you can run it directly to see the effect. After confirming that there are no problems, you can use the Copy button to copy the modified code, then open the source code in Terminal via ``nano`` cammand and paste it.
.. raw:: html
.. code-block:: python
from time import sleep
# GPIO pins connected to 74HC595 shift register
SDI = OutputDevice(17) # Serial Data Input
RCLK = OutputDevice(18) # Memory Clock Input (Register Clock)
SRCLK = OutputDevice(27) # Shift Register Clock
# Hexadecimal digit codes for a common cathode 7-segment display
segCode = [
0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d,
0x07, 0x7f, 0x6f, 0x77, 0x7c, 0x39, 0x5e, 0x79, 0x71
def hc595_shift(data):
# Shift 8 bits of data into the 74HC595
for bit in range(8):
# Set SDI high or low based on data bit
SDI.value = 0x80 & (data << bit)
# Trigger shift register clock
SRCLK.on()
sleep(0.001)
SRCLK.off()
# Latch data to output by triggering memory clock
RCLK.on()
sleep(0.001)
RCLK.off()
def display_all_on():
# Function to turn all segments on (for common cathode 7-segment display)
all_on_code = 0x3f
hc595_shift(all_on_code)
print("Displaying all segments on")
# Display each hexadecimal digit on 7-segment display
for code in segCode:
hc595_shift(code) # Shift the code into 74HC595
# Print the displayed segment code
print(f"Displaying segCode[{segCode.index(code)}]: 0x{code:02X}")
sleep(0.5) # Pause between displaying each digit
# Gracefully handle script interruption (e.g., Ctrl+C)
**Code Explanation**
#. This snippet imports the necessary classes for the project. ``OutputDevice`` from ``gpiozero`` is used to control hardware components connected to GPIO pins, and ``sleep`` from ``time`` is for adding delays.
#. SDI, RCLK, and SRCLK correspond to the Serial Data Input, Memory Clock Input (Register Clock), and Shift Register Clock pins of the 74HC595.
#. ``segCode`` is an array containing hexadecimal codes for each digit to be displayed on the 7-segment display.
segCode = [
#. This function shifts 8 bits of data into the 74HC595. It serially inputs each bit into ``SDI``, toggles ``SRCLK`` to shift the bit, and uses ``RCLK`` to latch the data to the output.
SRCLK.on()
sleep(0.001)
SRCLK.off()
RCLK.on()
sleep(0.001)
RCLK.off()
#. This function turns all segments of the display on by sending a specific code to ``hc595_shift``.
all_on_code = 0x3f
#. In the main loop, each code in ``segCode`` is sent to the display in sequence, with a delay between each.
#. This part of the code gracefully handles script interruption (like Ctrl+C).
