.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
π Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _3.1.5_c_pi5_mcp3008:
3.1.5 Battery Indicator(MCP3008)
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
In this project, we will make a battery indicator device that can
visually display the battery level on the LED Bargraph.
.. warning::
Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi.
.. image:: ../img/list2_Battery_Indicator.png
:align: center
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_bar_graph`
* - :ref:`cpn_mcp3008`
Schematic Diagram
SPICE0 Pin 24 10 8
SPIMOSI Pin 19 12 10
SPIMISO Pin 21 13 9
SPISCLK Pin 23 14 11
GPIO25 Pin 22 6 25
GPIO12 Pin 32 26 12
GPIO16 Pin 36 27 16
GPIO20 Pin 38 28 20
GPIO21 Pin 40 29 21
GPIO5 Pin 29 21 5
GPIO6 Pin 31 22 6
GPIO13 Pin 33 23 13
GPIO19 Pin 35 24 19
GPIO26 Pin 37 25 26
.. image:: ../img/schematic_battery_indicator_mcp3008.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../img/july24_3.1.5_battery_indicator_mcp3008.png
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/raphael-kit/c/3.1.5-2/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 3.1.5_BatteryIndicator.c -lwiringPi
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
After the program runs, give the 3rd pin of MCP3008 and the GND a
lead-out wire separately and then lead them to the two poles of a
battery separately. You can see the corresponding LED on the LED
Bargraph is lit up to display the power level (measuring range: 0-5V).
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
.. code-block:: c
#include
#include
#include
#define SPI_CHANNEL 0
#define SPI_SPEED 1000000 // 1MHz
#define VREF 3.3
int pins[10] = {6, 26, 27, 28, 29, 21, 22, 23, 24, 25};
int read_ADC(int channel)
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // Single-ended mode
buffer[2] = 0;
int value = ((buffer[1] & 3) << 8) | buffer[2];
return value;
void LedBarGraph(int value) {
for (int i = 0; i < 10; i++) {
if (i < value)
digitalWrite(pins[i], HIGH);
else
digitalWrite(pins[i],LOW);
int main(void)
if (wiringPiSetup() == -1) {
printf("setup wiringPi failed!\n");
printf("SPI setup failed!\n");
pinMode(pins[i], OUTPUT);
while (1) {
int analogVal = read_ADC(0); // MCP3008 CH0
if (analogVal < 0) continue;
float voltage = analogVal * VREF / 1023.0;
int level = analogVal * 10 / 1024;
if (level > 10) level = 10;
LedBarGraph(level);
printf("ADC Value: %d\tVoltage: %.2f V\tLevel: %d\n", analogVal, voltage, level);
delay(200);
Code Explanation
.. code-block:: c
buffer[1] = (8 + channel) << 4; // Single-ended mode, CH0~CH7
buffer[2] = 0;
int value = ((buffer[1] & 3) << 8) | buffer[2]; // Combine 10-bit result
return value;
This function reads analog values from the MCP3008 ADC chip using SPI.
The `channel` parameter selects one of the 8 analog inputs (CH0βCH7).
The MCP3008 returns a 10-bit digital value between 0 and 1023 representing the analog voltage.
.. code-block:: c
if (i < value)
digitalWrite(pins[i], HIGH); // Turn on LED (assumes active HIGH wiring)
else
digitalWrite(pins[i], LOW); // Turn off LED
This function controls a 10-LED bar graph display.
Each LED represents 1/10th of the voltage range.
LEDs are turned on in order up to the specified level.
Note: This version assumes LED anodes are connected to GPIOs and cathodes to GND (i.e. active HIGH).
.. code-block:: c
int main(void)
digitalWrite(pins[i], HIGH); // Initialize all LEDs to ON
while (1) {
int analogVal = read_ADC(0); // Read voltage on CH0
int level = analogVal * 10 / 1024; // Map to 0β10 levels
LedBarGraph(level); // Display level on LEDs
delay(200); // Update rate: 5 Hz
Main program logic:
- Initializes wiringPi and SPI communication.
- Sets GPIO pins as outputs for controlling the 10-LED bar.
- Continuously reads analog voltage via MCP3008 (CH0).
- Converts the reading to a voltage using `VREF = 3.3V`.
- Scales voltage to a 0β10 level bar graph and lights up LEDs.
- Displays the raw ADC value, voltage (in volts), and LED level via serial console.
This acts as a visual battery level indicator or analog voltmeter.
.. **Phenomenon Picture**
.. .. image:: ../img/image249.jpeg
:align: center
