.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.2.2_c_pi5_mcp3008:
2.2.2 Thermistor(MCP3008)
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
Just like photoresistor can sense light, thermistor is a temperature
sensitive electronic device that can be used for realizing functions of
temperature control, such as making a heat alarm.
.. image:: ../img/list2_2.2.2_thermistor.png
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_thermistor`
- |link_thermistor_buy|
* - :ref:`cpn_mcp3008`
Schematic Diagram
.. list-table::
:widths: 30 30 30 30
:header-rows: 1
* - T-Board Name
- physical
- WiringPi
- BCM
* - SPICE0
- pin24
- 10
- 8
* - SPIMOSI
- pin19
- 12
- 10
* - SPIMISO
- pin21
- 13
- 9
* - SPISCLK
- pin23
- 14
- 11
.. image:: ../img/schematic_2.2.2_thermistor_mcp3008.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../img/july24_2.2.2_thermistor_mcp3008.png
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/raphael-kit/c/2.2.2-2/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 2.2.2_Thermistor.c -o Thermistor -lwiringPi -lm
.. note::
-lm is to load the library math. Do not omit, or you will make
an error.
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
./Thermistor
With the code run, the thermistor detects ambient temperature which will
be printed on the screen once it finishes the program calculation.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code**
.. code-block:: c
#include
#include
#include
#include
#define SPI_CHANNEL 0 // CE0
#define SPI_SPEED 1000000 // 1MHz
int read_ADC(int channel) {
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // Single-ended mode + channel
buffer[2] = 0;
int value = ((buffer[1] & 3) << 8) | buffer[2];
return value;
int main(void) {
int analogVal;
if (wiringPiSetup() == -1) {
printf("setup wiringPi failed!\n");
printf("SPI setup failed!\n");
while (1) {
analogVal = read_ADC(0); // Read from CH0
// MCP3008 is 10-bit ADC (0–1023)
Vr = 3.3 * analogVal / 1023.0; // Assume Vref = 3.3V
Rt = 10000.0 * Vr / (3.3 - Vr); // Voltage divider, 10k resistor
temp = 1 / ((log(Rt / 10000.0) / 3950.0) + (1 / (273.15 + 25.0)));
cel = temp - 273.15;
Fah = cel * 1.8 + 32;
printf("Celsius: %.2f C Fahrenheit: %.2f F\n", cel, Fah);
delay(1000);
Code Explanation
.. code-block:: c
#include
#include
#include
#include
These header files include libraries for GPIO control (``wiringPi.h``), SPI communication (``wiringPiSPI.h``), standard I/O operations (``stdio.h``), and math functions (``math.h``) in C.
.. code-block:: c
Define constants for the SPI channel and SPI communication speed. Here, SPI channel 0 (CE0) and a clock speed of 1 MHz are used.
.. code-block:: c
This function reads analog data from a specified channel of the MCP3008 ADC.
.. code-block:: c
buffer[0] = 1;
buffer[2] = 0;
These lines format the SPI command according to the MCP3008 protocol: a start bit, configuration for single-ended mode, and the channel number.
.. code-block:: c
Transfer the SPI command and receive the 10-bit ADC data from MCP3008.
.. code-block:: c
Extract and combine the 10-bit ADC result from the returned SPI buffer.
.. code-block:: c
if (wiringPiSetup() == -1) { ... }
if (wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) { ... }
These lines initialize WiringPi and configure SPI. If initialization fails, the program exits.
.. code-block:: c
Reads the analog signal from MCP3008 channel 0, where the thermistor voltage divider is connected.
.. code-block:: c
Convert the digital ADC value into an analog voltage. The ADC range is 0–1023 with 3.3V reference voltage.
.. code-block:: c
Calculate the resistance of the thermistor using the voltage divider formula. A 10kΩ resistor is assumed in series with the thermistor.
.. code-block:: c
Use the B-parameter equation to convert the thermistor resistance to temperature in Kelvin.
**T(K) = 1 / [ln(Rt/Râ‚€)/B + 1/Tâ‚€]**, where
- R₀ = 10kΩ
- B = 3950
- T₀ = 25°C = 298.15K
.. code-block:: c
Convert the temperature from Kelvin to degrees Celsius.
.. code-block:: c
Convert the Celsius temperature to Fahrenheit.
.. code-block:: c
Display the temperature in both Celsius and Fahrenheit on the terminal with 2 decimal places of precision.
.. Phenomenon Picture
.. .. image:: ../img/image203.jpeg
