1.1.3 LED Bar Graph¶
Introduction¶
In this project, we sequentially illuminate the lights on the LED Bar Graph.
Schematic Diagram¶
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO18 |
Pin 12 |
18 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
GPIO23 |
Pin 16 |
23 |
GPIO24 |
Pin 18 |
24 |
GPIO25 |
Pin 22 |
25 |
SDA1 |
Pin 3 |
8 |
SCL1 |
Pin 5 |
9 |
SPICE0 |
Pin 24 |
10 |
8 |
Experimental Procedures¶
Step 1: Build the circuit.
Pay attention to the direction when connecting. If you connect it backwards, it will not light up.
cd ~/raphael-kit/c/1.1.3/
Step 3: Compile the code.
gcc 1.1.3_LedBarGraph.c -lwiringPi
After the code runs, you will see the LEDs on the LED bar turn on and off regularly.
If it does not work after running, or there is an error prompt: “wiringPi.h: No such file or directory”, please refer to C code is not working?.
#include <wiringPi.h>
#include <stdio.h>
int pins[10] = {0,1,2,3,4,5,6,8,9,10};
void oddLedBarGraph(void){
for(int i=0;i<5;i++){
int j=i*2;
digitalWrite(pins[j],HIGH);
delay(300);
digitalWrite(pins[j],LOW);
void evenLedBarGraph(void){
int j=i*2+1;
delay(300);
void allLedBarGraph(void){
for(int i=0;i<10;i++){
digitalWrite(pins[i],HIGH);
delay(300);
digitalWrite(pins[i],LOW);
int main(void)
for(int i=0;i<10;i++){ //make led pins' mode is output
pinMode(pins[i], OUTPUT);
oddLedBarGraph();
delay(300);
evenLedBarGraph();
delay(300);
allLedBarGraph();
delay(300);
Code Explanation
Create an array and assign it to the pin number corresponding to the LED Bar Graph (0,1,2,3,4,5,6,8,9,10) and the array will be used to control the LED.
int j=i*2;
delay(300);
Let the LED on the odd digit of the LED Bar Graph light on in turn.
int j=i*2+1;
delay(300);
Make the LED on the even digit of the LED Bar Graph light on in turn.
delay(300);
Let the LED on the LED Bar Graph light on one by one.
Phenomenon Picture
