.. include:: /index.rst
:start-after: start_hello_message
:end-before: end_hello_message
.. _intro_pironman5_promax:
Pironman 5 Pro MAX
Thanks for choosing our |link_pironman5_promax|.
.. image:: img/Pironman-5-Pro-Max.png
:width: 400
:align: center
Elevate your Raspberry Pi 5 experience with the |link_pironman5_promax|, our new flagship high-performance aluminum chassis. Designed for ultimate cooling, expansion, and a complete desktop-like experience, it's perfect for demanding applications like NAS, AI development, media centers, and advanced projects.
**Key Features**:
* **Dual NVMe & AI Expansion Hub**: Integrated PCIe Gen 2 switch with two M.2 M-key slots (2230/2242/2260/2280) for SSDs or AI accelerators (fully compatible with Hailo-8/8L). Configure for RAID 0/1 NAS, SSD+AI, or dual AI setups.
* **Comprehensive Cooling System**: Massive tower cooler with a PWM fan, plus **three** addressable RGB PWM fans, maintaining excellent thermal performance even under full load.
* **Dual Display & Multimedia**:
* **4.3" DSI Touchscreen** (800x480): Use as a secondary info display, status dashboard, or even a primary desktop monitor.
* **0.96" Smart OLED Display**: Shows real-time CPU, memory, temperature, disk usage, and IP.
* **Stereo 3W Speakers & 5MP Camera**: Ready for multimedia, video conferencing, or computer vision projects.
* **Enhanced User Interface & Control**:
* **Customizable RGB Ecosystem**: Six WS2812B addressable LEDs and three synchronized RGB fans for dynamic lighting effects.
* **IR Receiver** for media center remote control (e.g., Kodi, Volumio).
* **Safe Retro-style Metal Power Button** for graceful shutdown and boot.
* **RTC Battery Compartment** (for CR1220) for time-keeping.
* **Professional Connectivity & Layout**:
* **Rear-panel Reorganization**: Power input and dual standard HDMI ports are relocated to align with the USB ports for a clean, unified cable management look.
* **Full Port Access**: Dual HDMI, Gigabit LAN, 2x USB 3.0, 2x USB 2.0.
* **Labeled External GPIO Extender** for easy accessory connection.
* **Premium Industrial Design**: Robust dark aluminum alloy chassis with dark acrylic side panels, spring-loaded microSD card slot, and a modern desktop PC-inspired aesthetic.
.. note::
It is strongly recommended to use the official Raspberry Pi 27W power supply or a compatible high-quality alternative like the |link_sf_27w_supply| for the Pironman 5 Pro Max. Insufficient power may cause instability or reboots of the Raspberry Pi 5, especially under high load with NVMe drives and accessories.
**Content**
.. raw:: html
.. toctree::
:maxdepth: 1
About this Kit
what_do_we_need
assembly_instructions
install/install_the_os
set_up/set_up_pironman5
control/control_pironman5
hardware/hardware
optional_modules/optional_modules
home_server/home_server
ai_interaction/ai_interaction
compitable_nvme_ssd
faq
**Specifications**
* **Dimensions**: 140.9 x 77.0 x 138.7 mm
* **Material**:
* Main Chassis: Dark Anodized Aluminum Alloy
* Side Panels: Dark Acrylic
* **Supported Platform**: Raspberry Pi 5 (only)
* **Power Input**: USB Type-C, 5V/5A (Minimum 27W recommended)
* **Interfaces & Ports**:
* **Raspberry Pi 40-pin GPIO** (externally extended with clear labels)
* **MicroSD Card Slot** (with spring-loaded eject mechanism)
* **Rear Panel**:
* USB Type-C Power Input
* 2 x USB 2.0
* 2 x USB 3.0
* Gigabit Ethernet (RJ45)
* 2 x Standard HDMI (Type A) Ports (4Kp60 support)
* **Cooling System**:
* 1 x Large Tower Cooler with PWM-controlled Fan
* 3 x Addressable RGB PWM Fans (GPIO controlled, synchronizable)
* **Display & Multimedia**:
* 4.3-inch DSI Capacitive Touchscreen (800 x 480 pixels)
* 0.96-inch OLED Display (128x64) for system stats
* Stereo 3W Speakers
* 5 Megapixel Camera Module support
* **Storage & Expansion**:
* Integrated PCIe Gen 2 Switch
* 2 x PCIe 2.0 x1 M.2 M-key Slots
* Supported SSD/AI Card Sizes: 2230, 2242, 2260, 2280
* **Controls, Lighting & Features**:
* 18 WS2812B addressable RGB LEDs: 6 onboard and 12 integrated into the RGB fans.
* IR Receiver (38kHz)
* Metal Power Button (safe shutdown function)
* Real-Time Clock (RTC) Battery Holder (for CR1220 cell)
* **Build Quality**: Precision CNC aluminum body with tempered dark acrylic windows, designed for durability and sophisticated aesthetics.
