.. include:: /index.rst :start-after: start_hello_message :end-before: end_hello_message .. _intro_pironman5_mini: Pironman 5 Mini ========================================= Thanks for choosing our |link_pironman5_mini|. .. image:: img/pironman5_mini_pic.jpg :width: 400 :align: center |link_pironman5_mini| is the compact and streamlined model in the Pironman 5 series, offering a smaller form factor without compromising on core functionality. Featuring a sleek silver aluminum alloy body and transparent acrylic side panels, it delivers both style and performance in a space-saving design. **Key Features** * **Dedicated Controls**: Integrated power button for convenient operation. * **Efficient Cooling**: Active cooling system similar to the official Raspberry Pi cooler, plus an additional RGB side fan for enhanced airflow. * **Extra Functionality**: Built-in RTC battery and 4 WS2812-5050 RGB LEDs. * **Easy Expansion**: GPIO extender for flexible hardware connections. * **High-Speed Storage**: PCIe 2.0 M.2 M-key slot supporting NVMe SSDs in sizes **2230**, **2242**, **2260**, **2280**. Ideal for projects that demand **fast storage, stable performance, and a compact design**, the Pironman 5 Mini brings premium features to a smaller form factor. .. note:: It is recommended to use the official 27W power supply or |link_sf_27w_supply| for the Pironman 5 series products to avoid insufficient power supply, which may cause the Raspberry Pi 5 to reboot. .. toctree:: :maxdepth: 1 About this Kit what_do_we_need assembly_instructions install/install_the_os set_up/set_up_pironman5 control/control_pironman5 hardware/hardware optional_modules/optional_modules home_server/home_server compitable_nvme_ssd faq **Parameters** * Dimension: 67.8x98.6x101.5mm * Material * Main Body: Silver Aluminum Alloy * Two Side Panel: Black Transparent Acrylic * Support Platform: Raspberry Pi 5 * Power Input: USB Type C, 5V/5A * Interfaces * Raspberry Pi standard 40-Pin GPIO * Micro SD socket * USB Type C power input * 2 x USB 2.0 * 2 x USB 3.0 * Gigabit LAN port * 2 x 4Kp60 Micro HDMI Ports * 1 x Metal Power Button * 1 x RGB Fan (40x40x10mm) * 4 x WS2812-5050 RGB LEDs * 1 x Activer Cooler * 1 x PCIe 2.0 M.2 M key (2230, 2242, 2260, 2280) for NVMe SSD * 1 x 1220 Battery for RTC **Dimensional Drawing** .. image:: img/pironman5_mini_dimension.png :width: 800
