Building the PiPower¶
After getting familiar with the components in the package, we start to assemble PiPower.
In the next steps, there are a lot of details you need to notice, especially the assembly position of the battery and the clear acrylic back cover.
Assemble the PiPower Module¶
Assemble the Raspberry Pi¶
Assemble the Back Cover¶
Put the gap side of acrylic back cover under the switch of PiPower module so that you can easily power the PiPower on/off.
Plug the USB Cable¶
When the battery is about to be run out, you can charge the battery through the Micro USB port of the PiPower module.
