Keyboard ControlΒΆ
In this project, we will learn how to use the keyboard to remotely control the PiCrawler. You can control the PiCrawler to move forward, backward, left, and right.
Run the Code
cd /home/pi/picrawler/examples
sudo python3 keyboard_control.py
Press keys on keyboard to control PiCrawler! * w: Forward * a: Turn left * s: Backward * d: Turn right * esc: Quit
from time import sleep
import readchar
crawler = Picrawler([10,11,12,4,5,6,1,2,3,7,8,9])
speed = 90
manual = '''
w: Forward
a: Turn left
s: Backward
d: Turn right
esc: Quit
def show_info():
print("\033[H\033[J",end='') # clear terminal windows
print(manual)
def main():
show_info()
key = readchar.readkey()
key = key.lower()
if key in('wsad'):
if 'w' == key:
crawler.do_action('forward',1,speed)
elif 's' == key:
crawler.do_action('backward',1,speed)
elif 'a' == key:
crawler.do_action('turn left',1,speed)
elif 'd' == key:
crawler.do_action('turn right',1,speed)
sleep(0.05)
show_info()
elif key == readchar.key.CTRL_C or key in readchar.key.ESCAPE_SEQUENCES:
print("\n Quit")
break
sleep(0.02)
if __name__ == "__main__":
main()
How it works?
PiCrawler should take appropriate action based on the keyboard characters read. The lower()
function converts upper case characters into lower case characters, so that the letter remains valid regardless of case.
key = key.lower()
if key in('wsad'):
if 'w' == key:
elif 's' == key:
elif 'a' == key:
elif 'd' == key:
sleep(0.05)
show_info()
print("\n Quit")
break
