Open and Run the Code
In later chapters you will need to run the relevant code for the Raspberry Pi Pico. You can either open the .py file we provide directly or copy the corresponding code into the Thonny IDE to run it. A detailed tutorial has been provided in this section, either way you can quickly run the code to see the results.
However, before running the code, you need to make sure that the relevant libraries have been uploaded to the Raspberry Pi Pico. For a detailed tutorial, please refer to Upload the Libraries to Pico.
Open and Run Code Directly
Where there is code that needs to be run, there are prompts for what .py file in what paths need to be opened, and you can open and run them.
But first you need to make sure you have downloaded the package and uploaded the library by referring to Download and Upload the Code.
  1. Open Code
    For example, test.py.
    Double click on it and it will appear in a new window on the right, you can also open multiple codes at the same time.
    mps_open_code
  2. Select Correct Interpreter
    Plug the Pico into your computer with a micro USB cable and select the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
    mps_sec_inter
  3. Run the Code
    Click the Run current script button or just press F5 to run it.
    mps_run_it
    If there is information in the code that needs to be printed, it will appear in the Shell; otherwise, only the following information will appear.
    If the Shell window does not appear on your Thonny, you can click View -> Edit to open it.
    MicroPython v1.17 on 2021-09-02; Raspberry Pi Pico with RP2040
    Type "help()" for more information.
    >>> %Run -c $EDITOR_CONTENT
    • The first line prompts for the MicroPython version, the date, and your device information.
    • The second line suggests that you can type “help()” to get some help.
    • The third line is an instruction from Thonny telling the MicroPython interpreter on your Pico to run the contents of the script area - the ‘EDITOR_CONTENT’.
    • If there are any messages after the third line, they are usually the message you told MicroPython to print, or the error messages for the code.
  4. Stop Running
    mps_stop_it
    Click the Stop/Restart backend button to stop the running code. After stopping, the %RUN -c $EDITOR_CONTENT in the shell will disappear.
  5. Save or Save as
    If you make changes to the open example, you can press Ctrl+S or click the Save button on Thonny to save it.
    If you want to save this code as a separate file inside the Raspberry Pi Pico, click File -> Save As.
    mps_save_as
    Select Raspberry Pi Pico.
    mps_sec_pico
    Then enter the file name and the extension .py, and then click OK. You will then see your saved file on the Raspberry Pi Pico drive.
    mps_sec_name
    You can save your code under any name, but it’s best to describe what kind of code it is, and don’t name it with meaningless names such as abc.py. It is important to note that if you save the code file name as main.py, it will run automatically when the power is turned on.
Create File and Run it
Again, in the code section, we show the code directly and you can copy it to Thonny and run it by the following method.
  1. Create a new file
    Open Thonny IDE, click New button to create a new blank file.
    mps_new_file
  2. Copy Code
    Copy the code from the project to the Thonny IDE.
    mps_copy_file
  3. Select Correct Interpreter
    mps_sec_inter
  4. Run and Save the Code
    You need click Run Current Script or simply press F5 to run it. If your code has not been saved, a window will pop up asking to save to This computer or Raspberry Pi Pico.
    mps_where_save
    When you tell Thonny to save your program on the Raspberry Pi Pico, if you unplug the Pico and plug it into someone else’s computer, your program is still saved on the Pico.
    Choose the location you want to save, then enter the file name and the extension .py, and then click OK.
    mps_sec_name
    When your program is saved, it will run automatically and you will see following information in the Shell area.
  5. Stop Running
    mps_stop_it
  6. Open File
    If you want to open your saved code file, there are two ways:
    • The first is to click the open icon in the Thonny toolbar, just like when you save the program, you will be asked whether you want to open from This Computer or Raspberry Pi Pico, for example, click Raspberry Pi Pico and you will see a list of all programs you saved to your Pico.
    • The second one is to open the files preview directly by clicking View -> Files->, then double-clicking the corresponding .py file to open it.
