Data Types
Built-in Data Types
MicroPython has the following data types:
  • Text Type: str
  • Numeric Types: int, float, complex
  • Sequence Types: list, tuple, range
  • Mapping Type: dict
  • Set Types: set, frozenset
  • Boolean Type: bool
  • Binary Types: bytes, bytearray, memoryview
Getting the Data Type
You can get the data type of any object by using the type() function:
a = 6.8
print(type(a))
>>> %Run -c $EDITOR_CONTENT
<class 'float'>
Setting the Data Type
MicroPython does not need to set the data type specifically, it has been determined when you assign a value to the variable.
x = "welcome"
y = 45
z = ["apple", "banana", "cherry"]
print(type(x))
print(type(y))
print(type(z))
<class 'str'>
<class 'int'>
<class 'list'>
Setting the Specific Data Type
If you want to specify the data type, you can use the following constructor functions:
Example
Date Type
x = int(20)
int
x = float(20.5)
float
x = complex(1j)
complex
x = str(“Hello World”)
str
x = list((“apple”, “banana”, “cherry”))
list
x = tuple((“apple”, “banana”, “cherry”))
tuple
x = range(6)
range
x = dict(name=”John”, age=36)
dict
x = set((“apple”, “banana”, “cherry”))
set
x = frozenset((“apple”, “banana”, “cherry”))
frozenset
x = bool(5)
bool
x = bytes(5)
bytes
x = bytearray(5)
bytearray
x = memoryview(bytes(5))
memoryview
You can print some of them to see the result.
a = float(20.5)
b = list(("apple", "banana", "cherry"))
c = bool(5)
print(a)
print(b)
print(c)
20.5
['apple', 'banana', 'cherry']
True
Type Conversion
You can convert from one type to another with the int(), float(), and complex() methods: Casting in python is therefore done using constructor functions:
  • int() - constructs an integer number from an integer literal, a float literal (by removing all decimals), or a string literal (providing the string represents a whole number)
  • float() - constructs a float number from an integer literal, a float literal or a string literal (providing the string represents a float or an integer)
  • str() - constructs a string from a wide variety of data types, including strings, integer literals and float literals
a = float("5")
b = int(3.7)
c = str(6.0)
print(a)
print(b)
print(c)
You cannot convert complex numbers into another number type.
