Bull Fight¶
Make Pico-4wd a mischievous bull! On the open ground, it sleeps; when you appear in front of it, it will chase you and play; put a soccer in front of it and it plays.
Code¶
Open the
bull_fight.py
file under the path ofpico_4wd_car\examples
or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
For detailed tutorials, please refer to Open and Run Code Directly.
import pico_4wd as car
car.RADAR_REFERENCE = 25
car.RADAR_MAX_ANGLE = 45
car.RADAR_MIN_ANGLE = -45
car.RADAR_STEP_ANGLE = 10
MOTOR_FORWARD_POWER = 40
MOTOR_TURNING_POWER = 40
def main():
radar_data = car.radar_scan()
if isinstance(radar_data, int):
continue
radar_data = [str(i) for i in radar_data]
radar_data = "".join(radar_data)
paths = radar_data.split("1")
length_list = []
for path in paths:
length_list.append(len(path))
if max(length_list) == 0:
car.move("stop")
i = length_list.index(max(length_list))
pos = radar_data.index(paths[i])
pos += (len(paths[i]) - 1) / 2
delta = len(radar_data) / 3
if pos < delta:
car.move("right", MOTOR_TURNING_POWER)
elif pos > 2 * delta:
car.move("left", MOTOR_TURNING_POWER)
car.move("forward", MOTOR_FORWARD_POWER)
main()
finally:
car.move("stop")
car.set_light_off()
How it works¶
