APP Control
This section will guide you to use Sunfounder Controller APP to play pico-4wd remotely, which means you can use your phone/tablet to control it wandering around outdoors.
How to do?
  1. Coding
    To make things easier, let’s use app_test.py in the tests folder (this code will be explained later) for the first Sunfounder Controller experiment!
    After running the program (Pico RDP should also be working at this time), Pico-4wd does not show anything, while the Thonny script shows the following message:
    >>> %Run -c $EDITOR_CONTENT
        Connecting
        WebServer started on ws://192.168.4.1:8765
        start
  2. Install Sunfounder Controller
    Search for Sunfounder Controller in APP Store (or Google Play) and download it.
    _images/app_install.png
  3. Connect to mobile devices.
    Find my_4wd_car on the WLAN of the mobile phone (tablet), enter the password (12345678) and connect to it. This is an AP released by Pico RDP and is not connected to the World Wide Web.
    If you need to keep the phone (tablet) network, you can switch to STA mode, which will be discussed later.
    After the connection is successful, the Thonny script will show the IP of the newly connected device:
        Connecting
        start
        Connected from 192.168.4.3
  4. Open Sunfounder Controller , and you will see the home page,click the connect icon on the top right corner to complete the connection between Pico-4wd and the phone (tablet).
    _images/app_home_page.jpg
    • The big plus button in the middle can create a controller, and you can create multiple controller schemes in Sunfounder Controller.
    • Click on the exclamation mark icon in the upper left corner to view “ABOUT US”
    • The red letter on the upper right shows the current connection status of Sunfounder Controller. If it is connected to a device (such as Pico-4wd), it will become a white font.
    • The edit icon allows you to delete redundant controllers.
    • You will need to click the link icon at the top right to connect to the mobile device. It should be noted that the Sunfounder Controller can connect successfully only when the device is running the program (you will need to reconnect after re-burning the code).
  5. Create a controller, you will be able to see boxes (some are rectangles, some are squares), we need to adjust them to apply to app_test.py.
    _images/app_test_controller_1.jpg
    Click on area D and select the radar scanning widget.
    _images/app_test_controller_2.jpg
    Click on area H and sclect the Slider widget。
    _images/app_test_controller_3.jpg
    Click the save icon at the top right, and the controller will be saved. At the same time it enters the working state, and the empty widget box is hidden.
    At this time, the original save icon will become an edit icon, click on it to return to the edit state to adjust the widget.
    _images/app_test_controller_4.jpg
  6. Click the run icon next to the edit icon, Pico-4wd finally starts to move!
    If it fails to proceed as expected, or Disconnected is displayed next to the Run icon, please reconnect the Pico-4wd to the phone (tablet), and try again!
    • You will be able to see that the Pico-4wd radar is scanning, and the D box on the Sunfounder Controller will show the scan results.
    • If you flip the slider of the H box, the RGB Board at the rear of the car will lights up the corresponding lights.
How it works?
The communication between Pico-4wd and Sunfounder Controller is based on the websocket protocol.
Its function has been written in ws.py, we have loaded it in the chapter Import Pico-4wd Libraries.
The specific workflow of APP Control gameplay is as follows:
_images/flowchart_app_control.png
from ws import WS_Server
import json
import pico_4wd as car
NAME = 'my_4wd_car'
## Client Mode
# WIFI_MODE = "sta"
# SSID = "YOUR SSID HERE"
# PASSWORD = "YOUR PASSWORD HERE"
## AP Mode
WIFI_MODE = "ap"
SSID = ""
PASSWORD = "12345678"
ws = WS_Server(name=NAME, mode=WIFI_MODE, ssid=SSID, password=PASSWORD)
ws.start()
def on_receive(data):
    # write control codes here.
    # write sensor codes here.
ws.on_receive = on_receive
def main():
    print("start")
        ws.loop()
    main()
finally:
    car.move("stop")
    car.set_light_off()
This code constitutes the basic framework of APP control. Here, you need to pay attention to the following two parts:
  1. Setup websocket
    There are two connection mode between Sunfounder Controller and Pico-4wd car: One is AP mode, the other is STA mode.
    • AP Mode: You need to connect Sunfounder Contorller to the hotspot released by Pico-4wd car.
    • STA Mode: You need to connect Sunfounder Controller and Pico-4wd car to the same LAN.
    The default connection mode is AP Mode: The car releases the hotspot (the Wifi name is NAME in the code, here is my_4wd_car), the mobile phone (tablet) is connected to this WLAN. This mode allows you to remotely control Pico-4wd in any situation, but will make your phone (tablet) temporarily unable to connect to the Internet.
    NAME = 'my_4wd_car'
    ## Client Mode
    # WIFI_MODE = "sta"
    ## AP Mode
    WIFI_MODE = "ap"
    SSID = ""
    ws.start()
    You can also use STA mode: Let Pico-4wd car connects to your home WLAN, and your mobile phone (tablet) should also be connected to the same WLAN.
    This mode is opposite to the AP mode and will not affect the normal use of the mobile phone (tablet), but will limit your Pico-4wd car from leaving the WLAN radiation range.
    The way to start this mode is to comment out the three lines under ## AP Mode, uncomment the three lines under ## Client Mode, and change the SSID and PASSWORD to your home WIFI at the same time.
    NAME = 'my_4wd_car'
    ## Client Mode
    WIFI_MODE = "sta"
    SSID = "Sunfounder"
    ## AP Mode
    # WIFI_MODE = "ap"
    # SSID = ""
    # PASSWORD = "12345678"
    ws.start()
    After completing the connection mode settings, Websocket will set up and start the server.
    ws.start()
  2. Responding
    The specific operation code of Pico-4wd and Sunfounder Controller is written on the ``on_receive()’’ function. Usually, we need to write the codes for APP to control Pico-4wd on the front and the codes for APP to show Pico-4wd sensor data on the back.
    As shown below, we have written the controls code for the H area slider to control the number of lights on the RGB Board; and the sensor codes for the D area to show the radar detection results.
        num = int(data['H_region']*9/100)
        for i in range(0,num):
            car.write_light_color_at(i, [80, 50, 0])
        for i in range(num,8):
            car.write_light_color_at(i, [0, 0, 0])
        car.light_excute()
        data = car.get_radar_distance()
        print(data)
        ws.send_dict['D_region'] = data
    Finally, on_receive() will be assigned to ws.on_receive and then called by ws.loop.
Transfer Data
From APP to Pico-4wd
Let’s take a look at what kind of data Pico-4wd will get from the APP. Print data directly in on_receive.
    print(data)
You will be able to see the following string:
{'J_region': None, 'A_region': None, 'L_region': None, 'K_region': None, 'F_region': None, 'M_region': None, 'H_region': 50, 'Q_region': None, 'G_region': None, 'I_region': None, 'B_region': None, 'D_region': None, 'C_region': None, 'N_region': None, 'E_region': None, 'P_region': None, 'O_region': None}
As we can see, the value of H Box is 50 (H_region': 50), and the others are None. This is because we only add one control widget (H Box). The widget in the D area is not used for control but only for show.
We can also add other control widgets, and use the same method to view the values ​​sent by these widgets to Pico-4wd.
You can get the value of the corresponding widget by just using the label. As shown below, print the value of the H Box widget:
    print(data['H_region'])
    Connecting
    start
    50
    50
    50
As shown below, use the obtained H Box widget (Slider) value to control the RGB Board at the rear of the car.
    car.light_excute()
You can use API file to help you understand the functions in the code.
From Pico-4wd to APP
Now let’s see what kind of data Pico-4wd will send to the APP. The following code is used to obtain the ultrasonic detection distance.
    print(data)
    Connecting
    start
    Connected from 192.168.4.2
    [-10, 49.249]
    [-20, 37.417]
    [-30, 38.947]
    [-40, 36.193]
    [-50, 40.12]
    [-60, 36.431]
Now use the ``send_dict’’ function to show the distance value in D Widget.
    print(data)
APP Control Example
Now, please open de app_control.py in examples and try the complete APP remote control gameplay!
_images/app_control_example.jpg
import json
NAME = 'my_pico_car'
# Client Mode
# WIFI_MODE = "sta"
# SSID = "YOUR_SSID_HERE"
# PASSWORD = "YOUR_PASSWORD_HERE"
# AP Mode
WIFI_MODE = "ap"
SSID = ""
ws.start()
led_status = False
    global led_status
    #Move
    if 'K_region' in data.keys() and 'H_region' in data.keys():
        # print(data['K_region'])
        if data['K_region'] == "left":
            car.write_light_color_at(0, [0, 0, 0])
            car.write_light_color_at(1, [0, 0, 0])
            car.write_light_color_at(6, [50, 50, 0])
            car.write_light_color_at(7, [50, 50, 0])
        elif data['K_region'] == "right":
            car.write_light_color_at(0, [50, 50, 0])
            car.write_light_color_at(1, [50, 50, 0])
            car.write_light_color_at(6, [0, 0, 0])
            car.write_light_color_at(7, [0, 0, 0])
        car.light_excute()
        car.move(data['K_region'], data['H_region'])
    # RGB LED
    if 'M_region' in data.keys():
        led_status = data['M_region']
    # speed measurement
    ws.send_dict['A_region'] = car.speed()
    if led_status:
        # HUE color system, Red is 0, and Green is 120
        hue = car.mapping(car.speed(), 0, 70, 120, 0)
        rgb = car.hue2rgb(hue)
        car.set_light_bottom_color(rgb)
        car.set_light_off()
    # radar
    ws.send_dict['D_region'] = car.get_radar_distance()
    # greyscale
    ws.send_dict['L_region'] = car.get_grayscale_values()
def main():
    print("start")
        ws.loop()
    main()
finally:
    car.move("stop")
    car.set_light_off()
Widget List
The control widgets are shown in the table:
_images/app_widget_control.png
The data widgets are shown in the table:
_images/app_widget_display.png
