12. 寻宝游戏
在您的房间里布置一个迷宫,并在六个角落分别放置六张不同颜色的卡片。然后控制 PiCar-X 逐一寻找这些颜色卡片!
备注
您可以下载并打印色卡 PDF Color Cards 用于颜色检测。
运行代码
cd ~/picar-x/example
sudo python3 12.treasure_hunt.py
查看画面
运行代码后,终端将显示以下提示:
No desktop !
* Environment: production
* Debug mode: off
然后,您可以在浏览器中输入 http://<您的 IP>:9000/mjpg 查看视频画面,例如: http://192.168.18.113:9000/mjpg
../_images/display.png
代码
from picarx import Picarx
from time import sleep
from robot_hat import Music,TTS
from vilib import Vilib
import readchar
import random
import threading
px = Picarx()
music = Music()
tts = TTS()
manual = '''
Press keys on keyboard to control Picar-X!
    w: Forward
    a: Turn left
    s: Backward
    d: Turn right
    space: Say the target again
    ctrl+c: Quit
color = "red"
color_list=["red","orange","yellow","green","blue","purple"]
def renew_color_detect():
    global color
    color = random.choice(color_list)
    Vilib.color_detect(color)
    tts.say("Look for " + color)
key = None
lock = threading.Lock()
def key_scan_thread():
    global key
        key_temp = readchar.readkey()
        print('\r',end='')
        with lock:
            key = key_temp.lower()
            if key == readchar.key.SPACE:
                key = 'space'
            elif key == readchar.key.CTRL_C:
                key = 'quit'
                break
        sleep(0.01)
def car_move(key):
    if 'w' == key:
        px.set_dir_servo_angle(0)
        px.forward(80)
    elif 's' == key:
        px.backward(80)
    elif 'a' == key:
        px.set_dir_servo_angle(-30)
        px.forward(80)
    elif 'd' == key:
        px.set_dir_servo_angle(30)
        px.forward(80)
def main():
    global key
    Vilib.display(local=False,web=True)
    sleep(0.8)
    print(manual)
    sleep(1)
    _key_t = threading.Thread(target=key_scan_thread)
    _key_t.setDaemon(True)
    _key_t.start()
    tts.say("game start")
    sleep(0.05)
        if Vilib.detect_obj_parameter['color_n']!=0 and Vilib.detect_obj_parameter['color_w']>100:
            tts.say("will done")
            sleep(0.05)
        with lock:
            if key != None and key in ('wsad'):
                car_move(key)
                sleep(0.5)
                px.stop()
                key =  None
            elif key == 'space':
                key =  None
            elif key == 'quit':
                _key_t.join()
                print("\n\rQuit")
                break
        sleep(0.05)
if __name__ == "__main__":
        main()
    except Exception as e:
        print(f"ERROR: {e}")
    finally:
        Vilib.camera_close()
        px.stop()
        sleep(.2)
工作原理
要理解此代码的基本逻辑,您可以关注以下关键部分:
  1. 初始化与导入: 代码开头的导入语句用于了解所使用的库和模块。
  2. 全局变量: 定义全局变量,例如 colorkey,这些变量贯穿整个代码,用于跟踪目标颜色和键盘输入。
  3. renew_color_detect() : 该函数从颜色列表中随机选择一个颜色,并将其设置为检测目标。同时,使用语音合成功能播报所选颜色。
  4. key_scan_thread() : 该函数运行在单独的线程中,不断扫描键盘输入,并更新 key 变量为按下的键值。它使用锁机制确保线程访问的安全性。
  5. car_move(key) : 根据键盘输入( key )控制 PiCar-X 的移动。该函数设置机器人的方向和移动速度。
  6. main() : 代码的主要逻辑协调函数,其功能包括:
    • 初始化摄像头并开始显示实时画面。
    • 创建独立线程以扫描键盘输入。
    • 通过语音播报宣布游戏开始。
    • 进入一个循环:
      • 检查是否检测到颜色目标对象,并在检测到有效对象时触发相应动作。
      • 处理键盘输入以控制机器人并与游戏交互。
    • 处理游戏退出逻辑和诸如 KeyboardInterrupt 的异常情况。
    • 确保退出时关闭摄像头并停止 PiCar-X。
通过理解代码的这些关键部分,您可以掌握 PiCar-X 机器人如何响应键盘输入, 以及如何利用摄像头和音频输出功能检测并与特定颜色的目标对象进行交互。
