.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Dual NVMe Raft =============================================== .. image:: img/O0917V10-pic.jpg :align: center The **Dual NVMe Raft** enables you to connect two M.2 peripheral devices (such as NVMe drives and other PCIe accessories) to the Raspberry Pi 5's PCIe interface. The Dual NVMe Kit integrates a PCIe Gen 2 switch with two M.2 M-key PCIe slots supporting 2230, 2242, 2260, and 2280 sizes, allowing the installation of two NVMe Gen2 SSDs or AI accelerators. Users can configure two NVMe SSDs in software RAID 0 or RAID 1 for NAS setups, combine one AI accelerator with one NVMe SSD to enhance AI performance, or install two AI accelerators for even more powerful AI capabilities. .. note:: It is recommended to use the official 27W power supply for the Raspberry Pi 5 when using it with either Dual NVMe Raft or General NVMe PIP, to ensure sufficient and stable power delivery. Using unofficial, underpowered, or non-compliant power adapters may result in SSDs failing to operate properly. .. warning:: Never hot-plug NVMe SSDs as it may result in damage to your devices. ----------------------------------------------------------------------- **Features** - Dual-channel PCIe 2.0 interface with a peak transfer rate of up to 500 MB/s - Compatible with M.2 NVMe SSDs using the M-Key interface; supports sizes 2230, 2242, 2260, and 2280 - Onboard 3.3V power supply supports up to 3A output - Since the Raspberry Pi's PCIe interface provides only 1A (5W), an external 5V power source is recommended when higher power (up to 10W) is required - Includes a 2-pin 2.54mm header and cable for additional external power input - Designed to mount on the back of the Raspberry Pi without interfering with active cooling or other compatible expansion boards - Connects to the Raspberry Pi via an FPC (Flexible Printed Circuit) cable - Equipped with three status LEDs: STA1 and STA2 indicate activity on each PCIe channel, while PWR shows power status ----------------------------------------------------------------------- **Hardware Overview** .. image:: img/O0917V10.png :align: center * **PCIe Port**: Connects to the Raspberry Pi via an FPC cable to transfer PCIe signals between the board and the Pi. * **Extra Power Input**: Provides additional 5V input when higher power is needed for NVMe SSDs. Useful when the Pi’s PCIe interface cannot supply enough current. * **Power Indicator**: Indicates whether the board is receiving power. If off, check the PCIe cable or external power. * **Force Enable**: Forces the 3.3V power supply to turn on regardless of PCIe signal. Use this jumper if the system doesn't provide the power-enable signal. * **NVMe SSD Slot**: Accepts M.2 NVMe SSDs (M-Key), compatible with 2230, 2242, 2260, and 2280 form factors. * **STA Indicator**: Indicates the activity status of each NVMe SSD slot. Blinks during data transfer or device activity. ----------------------------------------------------------------------- **Assembly Instructions** * :download:`[PDF]Component List and Assembly of Dual NVMe Raft `
