32. Stopwatch¶
In this exciting project, we will learn how to use a 4-digit 7-segment display to create a functional stopwatch. By the end of this lesson, you’ll understand how to control a multi-digit 7-segment display, and you’ll be able to build a simple stopwatch that tracks time in minutes and seconds. Get ready to dive into the world of digital displays and enhance your Arduino skills!
By the end of this lesson, you will:
Learn how to multiplex a 4-digit 7-segment display.
Write code to display numbers on a single digit.
Create a scrolling number display.
Implement a stopwatch using a 4-digit 7-segment display to track minutes and seconds.
Learn
AND
operator and>>
operator.
Learn 4-Digit 7-Segment Display¶
Find the 4-Digit 7-segment display.
A 7-segment display is an 8-shaped component that packages 7 LEDs. Each of the LEDs in the display is given a positional segment with one of its connection pins led out from the rectangular plastic package. These LED pins are labeled from “a” to “g” representing each individual LED.
A 4-digit display combines four 7-segment displays, each representing a single digit. To reduce the number of pins needed, the segments of each display are multiplexed, meaning each segment pin is connected to all corresponding segment pins of the other displays.
This reduces the pin count but increases the control complexity. For example, applying voltage to the “a” pin lights up the “a” segments of all digits. To control which digit displays the segment, each digit has a separate control pin(d1 ~ d4).
As a result if we want to display the number 2222, we have to apply voltage to the d1, d2, d3 and d4 because all displays will show a digit. We also need to apply voltage to inputs a, b, d, e, g, dp as shown below:
Pinout
A typical 4-digit 7-segment display has 12 pins, with six pins on each side.
Four pins (d1, d2, d3, and d4) control the individual digits. The remaining pins correspond to the segments.
Common Cathode or Common Anode
To determine whether a 4-digit 7-segment display is common cathode or common anode, you can use a multimeter. You can also use a multimeter to test if each segment of the display is working properly, as follows:
Set the multimeter to diode test mode. The diode test is a function of the multimeter used to check the forward conduction of diodes or similar semiconductor devices (such as LEDs). The multimeter passes a small current through the diode. If the diode is intact, it will allow the current to pass.
Insert the 4-digit 7-segment display into a breadboard. Insert a wire in the same row as pin d1 of the display, and touch it with the black lead of the multimeter. Insert another wire in the same row as pin e of the display, and touch it with the red lead.
Observe whether any LED segment lights up. If so, it indicates that the display is common cathode. If not, swap the red and black leads; if a segment lights up after swapping, it indicates that the display is common anode.
Our kit includes a common cathode 4-digit 7-segment display. Set control pins d1-d4 to LOW and segment pins a-g to HIGH to make it work.
Question
If you want the leftmost digit (d1) of the 4-digit 7-segment display to show “2”, what should be the levels of d1~d4 and a~g pins?
7-segment Display |
HIGH or LOW |
7-segment Display |
HIGH or LOW |
d1 |
a |
d2 |
b |
d3 |
c |
d4 |
d |
e |
f |
g |
dp |
Build the Circuit¶
Components Needed
1 * Arduino Uno R3 |
1 * 4-digit 7-segment Display |
4 * 220Ω Resistor |
1 * Multimeter |
1 * USB Cable |
1 * Breadboard |
Building Steps
Follow the wiring diagram, or the steps below to build your circuit.
Insert the 4-digit 7-segment display into the breadboard.
Insert four 220Ω resistors into the breadboard.
Connect the control pin d1 to one side of the first resistor. Connect the other side of the resistor to pin 10 of the Arduino Uno R3. This connects the control pin d1 to pin 10 through the resistor.
Similarly, connect d2 to pin 11, d3 to pin 12, and d4 to pin 13.
Now, connect the adp pins to pins 2~9 of the Arduino according to the wiring table.
7-segment Display |
Arduino Uno R3 |
a |
b |
c |
d |
e |
f |
7 |
g |
8 |
dp |
9 |
Code Creation - Displaying 2 on One Digit¶
Now let’s write code to display a number on one digit of the 4-digit 7-segment display.
Open the Arduino IDE and start a new project by selecting “New Sketch” from the “File” menu.
Save your sketch as
Lesson32_Show_2_One_Digit
usingCtrl + S
or by clicking “Save”.First, create two arrays to store the segment and digit pins of the 4-digit 7-segment display.
// Define the pins of the segments and the digits on the 4-digit 7-segment display
int segmentPins[] = { 2, 3, 4, 5, 6, 7, 8, 9 }; // Segments a~g and dp (decimal point)
int digitPins[] = { 10, 11, 12, 13 }; // Digits d1-d4
In the
void setup()
function, set all pins as outputs. Since this is a common cathode 4-digit 7-segment display, set all segment pins toLOW
and all digit pins toHIGH
to initially turn off the display.
// Set all segment pins as output
for (int i = 0; i < 8; i++) {
pinMode(segmentPins[i], OUTPUT);
digitalWrite(segmentPins[i], LOW); // Ensure all segments are off initially
// Set all digit pins as output and turn them off (common cathode, so HIGH is off)
for (int i = 0; i < 4; i++) {
pinMode(digitPins[i], OUTPUT);
digitalWrite(digitPins[i], HIGH);
In the
loop()
function, to activate the first digit on the left (d1), set its state toLOW
. If you want to activate the first digit on the right (d4), change0
to3
digitalWrite(digitPins[0], LOW); // Turn on first digit
To display a number, like 2, you need to set segments a, b, d, e, and g to HIGH. This will display the number 2.
digitalWrite(digitPins[1], LOW); // Turn on first digit
digitalWrite(segmentPins[0], HIGH); //Turn on segment a
digitalWrite(segmentPins[1], HIGH); //Turn on segment b
digitalWrite(segmentPins[3], HIGH); //Turn on segment d
digitalWrite(segmentPins[4], HIGH); //Turn on segment e
digitalWrite(segmentPins[6], HIGH); //Turn on segment g
Upload the code to the Arduino Uno R3 board, and you should see the first digit on the left display 2.
Code Creation - Scrolling Numbers on One Digit¶
In the previous project, we learned how to display a single number like 2 on one digit. But what if we want to scroll through numbers 0~9? Using the same method would be very lengthy.
In Lesson 28, we learned the binary, decimal, and hexadecimal codes for the numbers 0-9 on a common cathode display.
Number |
Binary |
Decimal |
Hexadecimal |
0 |
B00111111 |
63 |
0x3F |
B00000110 |
0x06 |
B01011011 |
91 |
0x5B |
B01001111 |
79 |
0x4F |
B01100110 |
102 |
0x66 |
B01101101 |
109 |
0x6D |
B01111101 |
125 |
0x7D |
7 |
B00000111 |
7 |
0x07 |
8 |
B01111111 |
127 |
0x7F |
9 |
B01101111 |
111 |
0x6F |
Here’s how to use this to scroll through numbers 0~9 on one digit.
Open the sketch you saved earlier,
. Hit “Save As…” from the “File” menu, and rename it toLesson32_Scroll_Numbers_One_Digit
. Click “Save”.Store the binary codes for numbers 0~9 in the array
numArray[]
//display 0,1,2,3,4,5,6,7,8,9
int numArray[] = { B00111111, B00000110, B01011011, B01001111, B01100110, B01101101, B01111101, B00000111, B01111111, B01101111 };
Now, create a function to display the selected number on the chosen digit.
void displayNumberOnDigit(int number, int digit) {
// Turn off all digits to prevent ghosting when switching numbers
// Turn off digit (common cathode -> HIGH is off)
// Set the segments for the current number
int value = numArray[number];
digitalWrite(segmentPins[i], (value >> i) & 1); // Set each segment
// Turn on the selected digit (common cathode -> LOW is on)
digitalWrite(digitPins[digit], LOW);
Turns off all digits to prevent ghosting, especially when changing the displayed number.
Uses a bitwise operation to determine which segments to light up for each number.
// Set the segments for the current number int value = numArray[number]; for (int i = 0; i < 8; i++) { digitalWrite(segmentPins[i], (value >> i) & 1); // Set each segment }
Here, the element from the array
numArray[]
is assigned to the variablevalue
. Ifnumber
is 2, the third element (B01011011
) fromnumArray[]
is assigned tovalue
.Then, a
for
loop writes each of the 8 bits ofB01011011
(excluding the B) to the arraysegmentPins[i]
usingdigitalWrite()
. This means segments a, b, d, e, and g are set to 1, and c, f, and dp are set to 0, displaying the number 2.&
is theAND
operator, which performs a bitwiseAND
operation on the numbers.1&1
equals 1,1&0
equals 0.
is the right shift operator, which shifts the bits of the number to the right by the specified number of positions. For example, ifi
is 1,B01011011
shifts right by one bit, dropping the rightmost bit and adding a 0 on the left. Ifi
is 2,B01011011
shifts right by two bits, dropping the two rightmost bits and adding two 0s on the left.The result of the right shift is then performed a bitwise AND with 1 to get either 1 or 0.
Activates only the digit where the number should be displayed.
In the
void loop
main program, use afor
loop to make the first digit on the left scroll through numbers 0 to 9.
// Display numbers 0 to 9 sequentially on the first digit (D1)
for (int num = 0; num < 10; num++) {
displayNumberOnDigit(num, 0); // Display the number on digit 1 (index 0)
delay(1000); // Display each number for 1 second
The complete code is shown below. You can upload it to the Arduino Uno R3, and you will see the first digit on the left scroll through numbers 0 to 9.
int segmentPins[] = { 2, 3, 4, 5, 6, 7, 8, 9 }; // Segments A-G and DP (decimal point)
int digitPins[] = { 10, 11, 12, 13 }; // Digits D1-D4
Question
In programming, bitwise operations like AND
and OR
are crucial for manipulating individual bits of data. The bitwise AND
operation (&), compares each bit of its operands, resulting in 1 if both bits are 1, and 0 otherwise. Conversely, the bitwise OR
operation (|
), results in 1 if at least one of the bits is 1, and 0 only if both bits are 0.
Given this information, consider the expression (B01011011 >> 2) | 1
. After right-shifting the binary number B01011011
by 2 positions, what is the result of applying the bitwise OR with 1?
Code Creation - Stopwatch¶
Previously, we learned how to display a single digit and scroll through numbers on one digit. Now, let’s learn how to use the 4-digit 7-segment display to create a stopwatch.
To create a stopwatch, you need the left two digits to display minutes and the right two digits to display seconds.
When the seconds count reaches 59, it resets to 0, and the minute count increases by 1.
When the minute count reaches 99, it resets to 0.
. Hit “Save As…” from the “File” menu, and rename it toLesson32_Stopwatch
. Click “Save”.Now create 3 variables to store time components,
previousMillis
is used to keep track of time since the last update,seconds
andminutes
store the stopwatch time.
int segmentPins[] = {2, 3, 4, 5, 6, 7, 8, 9}; // Segments A-G and DP (decimal point)
int digitPins[] = {10, 11, 12, 13}; // Digits D1-D4
// Variables to store time components
unsigned long previousMillis = 0; // Stores the last time the display was updated
int seconds = 0; // Stores the second count
int minutes = 0; // Stores the minute count
In the
void loop()
function:
Use
millis()
function to return the number of milliseconds since the Arduino board began running the current program.Then increment the seconds once every 1000 milliseconds (one second). When seconds reach 60, it resets to 0 and increments minutes. If minutes reach 100, it resets to 0, thereby starting the count again.
updateDisplay()
is called within each loop iteration to actively multiplex the display based on the current seconds and minutes.
unsigned long currentMillis = millis(); // Get the current time in milliseconds
if (currentMillis - previousMillis >= 1000) { // Check if a second has passed
previousMillis = currentMillis; // Reset the timer
seconds++; // Increment the seconds
if (seconds >= 60) { // Check if 60 seconds have passed
seconds = 0; // Reset seconds
minutes++; // Increment the minutes
if (minutes > 99) { // Check if 100 minutes have passed
minutes = 0; // Reset minutes
updateDisplay(); // Update the display to show the current time
About
updateDisplay()
function: Instead of setting the display once per second,updateDisplay()
is called continuously in the main loop. It cycles through each digit, turning it on for a short duration with the correct segments lit, then turns it off again. This process repeats quickly to give the appearance of a stable display.
void updateDisplay() {
for (int digit = 0; digit < 4; digit++) {
setDigitValues(minutes, seconds, digit);
digitalWrite(digitPins[digit], LOW); // Turn on current digit
delay(5); // Delay to keep the digit visible
digitalWrite(digitPins[digit], HIGH); // Turn off digit
About
setDigitValues()
function:setDigitValues()
takes care of setting the segments for each digit based on the current time (minutes and seconds). This function is called each time a digit is activated to ensure it shows the correct value.
void setDigitValues(int mins, int secs, int digit) {
int values[] = {
mins / 10, // tens of minutes
mins % 10, // ones of minutes
secs / 10, // tens of seconds
secs % 10 // ones of seconds
int value = numArray[values[digit]];
for (int segment = 0; segment < 8; segment++) {
digitalWrite(segmentPins[segment], (value >> segment) & 1);
Your complete code is shown below. You can now upload it to the Arduino board to see the stopwatch effect on the 4-digit 7-segment display.
int values[] = {
Finally, remember to save your code and tidy up your workspace.
Summary
In this lesson, we explored the functionality of the 4-digit 7-segment display and learned how to control it using an Arduino. We started by displaying a single number on one digit and then progressed to scrolling through numbers. Finally, we combined these skills to create a simple stopwatch that displays minutes and seconds. This project not only taught us about digital displays but also enhanced our programming skills with Arduino. Well done on completing this lesson, and keep experimenting to create even more amazing projects!
