16. Summer Fan
As summer approaches, it’s the perfect time to dive into a fun and engaging project. In this lesson, you’ll learn how to build a simple yet fascinating summer fan using Arduino. We’ll explore the fundamentals of motor control, the importance of using a motor driver, and how to control motor speed and direction with buttons. By the end of this lesson, you’ll be able to create a project that mimics a real-life fan, just in time to beat the summer heat!
By the end of this lesson, you will be able to:
Learn the purpose and functionality of the L293D chip.
Build a circuit using an Arduino, motor, and motor driver.
Write Arduino code to control motor speed and direction.
Utilize buttons to adjust motor speed, simulating the controls of a fan.
Build the Circuit
Components Needed
1 * Arduino Uno R3 |
1 * Motor |
4 * Button |
1 * L293D Chip |
1 * USB Cable |
1 * Breadboard |
Jumper Wires |
1 * Multimeter |
1 * Breadboard Power Module |
1 * 9V Battery |
1 * Battery Cable |
Building Steps
Follow the wiring diagram, or the steps below to build your circuit.
1. Connecting the L293D Chip
Normally, connecting a motor’s terminals directly to a battery or the GND and 5V pins on a control board will make it spin.
However, to control a motor programmatically, connect it to the signal pins on an Arduino board. These pins only output about 20mA, not enough for a motor, hence the need for a motor driver like the L293D.
The L293D is a 4-channel driver capable of handling high voltages and currents, suitable for driving DC and stepper motors among other inductive loads. It works with standard DTL, TTL logic levels.
The L293D has two power supply pins, Vcc1 and Vcc2. Vcc2 powers the motor, while Vcc1 powers the chip itself. For a small-sized DC motor, connect both pins to +5V.
Pin EN is an enable pin and only works with high level; A stands for input and Y for output.
When pin EN is High level, if A is High, Y outputs high level; if A is Low, Y outputs Low level.
When pin EN is Low level, the L293D does not work.
EN |
A |
Y |
H |
H |
H |
H |
L |
L |
L |
X |
X |
Let’s now build a circuit to test this motor driver chip.
When using motors, servos, and other actuators, it’s recommended to use an external power supply to avoid damaging the main board. Insert the breadboard power module into the breadboard, then use a jumper wire to connect the negative rail of the breadboard to the GND of the Arduino Uno R3 to achieve a common ground.
The order of the positive and negative terminals on the breadboard in the wiring diagram is reversed compared to the breadboard provided in the kit.
In actual wiring, you need to insert the breadboard power module from the higher number side (60~65) so that the “-” of the power module goes into the negative rail “-” of the breadboard, and the “+” into the positive rail “+”.
Insert the L293D chip across the middle notch of the breadboard. Make sure the notch on the chip faces left.
Connect the pins of the L293D chip as follows.
1(1,2EN): Connect to the positive rail of the breadboard to enable the chip.
4(GND): Connect to the negative rail of the breadboard to ground the chip.
8(VCC2): Connect to the positive rail of the breadboard to provide power to the motor.
16(VCC1): Connect to the positive rail of the breadboard to power the chip.
You can now connect the A pins of the chip (1A, 2A, 3A, 4A) to either 5V or GND to observe the voltage at the Y pins (1Y, 2Y, 3Y, 4Y). Use 1A and 1Y for testing, first connect 2(1A) to the positive rail of the breadboard.
Adjust the multimeter to the 20 volts DC setting.
Touch the red lead of the multimeter to pin 3(1Y), and the black lead to any GND.
Record the voltage at pin 3(1Y) in the table below.
1,2EN |
1A |
1Y |
5V |
5V |
≈5.04V |
5V |
0V |
Now connect 2(1A) to the negative rail of the breadboard.
Similarly, measure the voltage at 3(1Y) using the multimeter, and fill in the results in the table.
1,2EN |
1A |
1Y |
5V |
5V |
≈5.04V |
5V |
0V |
≈0V |
From the above test results, it is evident that when EN is high, the L293D chip starts working, and if A pins (1A, 2A, 3A, 4A) on the chip are High, the Y pins (1Y, 2Y, 3Y, 4Y) output high level; if A pins (1A, 2A, 3A, 4A) are Low, the Y pins (1Y, 2Y, 3Y, 4Y) output Low level.
Now insert pin 2 (1A) of the L293D chip into pin 10 of the Arduino Uno R3, and pin 7 (2A) into pin 9, thus controlling the input of channels 1 and 2 through pins 9 and 10.
2. Connecting the Motor
This is a 3V DC motor. When you give a high level and a low level to each of the 2 terminals, it will rotate.
Motors play an integral part in our daily lives. They’re everywhere! From the electric fans that cool us on hot days, the mixers that help us make delicious cakes, to the electric cars that whizz by on the streets - motors make things move!
A motor is like the heart of a machine. It converts electrical energy into mechanical energy, making our toys, appliances, and even big vehicles come to life!
Here’s how it works: when electricity is supplied to a motor, it generates a magnetic field. This magnetic field then interacts with other magnets within the motor, causing the motor to spin. This spin, like spinning a top, can then be used to move wheels, propellers, or any other moving parts of a machine.
Now connect the two terminals of the motor to pins 3 (1Y) and 6 (2Y) of the L293D chip.
The truth table for controlling the motor is as follows.
1,2EN |
1A |
2A |
Motor State |
H |
H |
L |
Motor rotates |
H |
L |
H |
Motor rotates in reverse |
H |
L |
L |
Motor inactive |
H |
H |
H |
Motor inactive |
3. Connecting 4 Buttons
We need 4 buttons to control the motor speed, each button representing a speed setting.
Insert 4 buttons on the breadboard, each spanning the middle groove.
Connect the lower left pin of each button to Arduino pins 4, 5, 6, 7 respectively.
Finally, connect the upper right pin of each button to GND. We are not using pull-down resistors here; planning to use Arduino’s internal pull-up for simpler wiring.
Code Creation - Making the Motor Move
Let’s write the code to see how to drive a motor.
Open the Arduino IDE and start a new project by selecting “New Sketch” from the “File” menu.
Save your sketch as
Lesson16_Motor
usingCtrl + S
or by clicking “Save”.Initialize the motor control pins.
// Define motor control pins
int motor1A = 10;
int motor2A = 9;
// Set motor control pins as outputs
pinMode(motor1A, OUTPUT);
pinMode(motor2A, OUTPUT);
In
void loop()
use thedigitalWrite()
function to writeHIGH
andLOW
states to the two control pins of the motor, making the motor rotate.
int motor1A = 10;
int motor2A = 9;
// Rotate the motor forward
digitalWrite(motor1A, HIGH);
digitalWrite(motor2A, LOW);
At this point, you can upload the code to the Arduino, and you will find that the motor moves.
Next, let’s see how to reverse the direction of the motor and stop it. To reverse the motor direction, simply swap the levels of the two control pins.
// Rotate the motor in reverse
digitalWrite(motor1A, LOW);
digitalWrite(motor2A, HIGH);
delay(2000); // Motor runs for 1 seconds
To stop the motor, simply set both control pins to either
HIGH
orLOW
, which will stop the motor.
int motor1A = 10;
int motor2A = 9;
// Stop the motor
delay(3000); // Motor stops for 2 second
The code is complete, you can upload it to the Arduino board. Afterwards, you will notice the motor rotates forward for 2 seconds, reverses for 2 seconds, then stops for 3 seconds, and this cycle repeats.
Code Creation - Summer Fan
Let’s explore how to use four buttons to control motor speed, similar to adjusting a fan’s speed in real life.
Open the sketch you saved earlier,
Lesson16_Motor
. Hit “Save As…” from the “File” menu, and rename it toLesson16_Summer_Fan
. Click “Save”.Here we need to control the speed of the motor’s rotation, so create a
motorRotate()
function to control its speed.
In the function, use the
analogWrite()
function to write a PWM value to themotor1A
pin, motor2A set to 0, thus the motor will rotate in one direction.The higher the
speed
value, the faster the motor rotates.
int motor1A = 10;
int motor2A = 9;
motorRotate(150);
void motorRotate(int speed) {
analogWrite(motor1A, speed); // Control motor speed
analogWrite(motor2A, 0); // Control motor speed
After uploading the code to the Arduino board, you will find that the motor rotates in one direction. When you change the value of
motorRotate(150)
, the motor speed changes, the higher the value, the faster the speed.Now initialize four button pins.
const int motor1A = 10;
const int motor2A = 9;
// Define button pins
const int button1 = 4;
const int button2 = 5;
const int button3 = 6;
const int button4 = 7;
In
void setup()
set all four buttons toINPUT_PULLUP
// Initialize button pins as INPUT_PULLUP
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT_PULLUP);
pinMode(button4, INPUT_PULLUP);
Now write the main program part. When
button1
is read asLOW
, it means button1 is pressed, at this time the motor speed should be set to 0, i.e., turn it off.
if (digitalRead(button1) == LOW) { // Check if first button is pressed
motorRotate(0); // Turn off the motor
Similarly, when
button2
is pressed, set the motor speed to 150.
} else if (digitalRead(button2) == LOW) { // Check if second button is pressed
motorRotate(150); // Set speed for low
When
button3
is pressed, set the motor speed to 200.
} else if (digitalRead(button3) == LOW) { // Check if third button is pressed
motorRotate(200); // Set speed for medium
Finally, if
button4
is pressed, set the motor speed to 250.
} else if (digitalRead(button4) == LOW) { // Check if fourth button is pressed
motorRotate(250); // Set speed for high
Here is your complete code. At this point, you can upload the code to your Arduino board and then press each of the 4 buttons to see if the motor speed changes.
Finally, remember to save your code and tidy up your workspace.
Question
How should the code be modified if you want to control the motor’s direction as well?
Summary
In this lesson, we delved into the working principles of the L293D motor driver chip and the basic operation of motors. You learned how to make a motor rotate and how to control its direction using Arduino. Finally, we put it all together in a complete project that simulates a fan, using four buttons to control different motor speeds.
