Quick Start with Scratch ================================== In this chapter, you'll learn how to **quickly open and run example projects in Scratch (Mammoth Coding)** to see your GalaxyRVR in action. If you want to learn how to create these scripts from scratch, please refer to the :ref:`programming_scratch` chapter. .. note:: * The GalaxyRVR’s R3 board comes with firmware that supports the RoboPilot App and Mammoth Coding. * If you have overwritten the firmware and need to restore communication, follow :ref:`update_r3_firmware`. How to Quickly Open a Scratch Example ------------------------------------- #. Download the example codes from the link below: * :download:`GalaxyRVR Code File ` #. Extract the downloaded file and transfer the ``scratch_codes`` folder to your mobile device. You can use any file transfer tool, such as **ES File Explorer** or **File Transfer Assistant**. .. image:: img/scratch_mobile_save.png :width: 400 #. Search for **Mammoth Coding** on **Google Play** or the **Apple App Store** and install it. .. image:: img/scratch_app_install.png :width: 600 #. Before using the GalaxyRVR for the first time, fully charge the battery with the supplied Type-C USB cable. After charging, turn the power on. .. raw:: html #. To start the ESP32 CAM, switch the mode to **Run** and press the **Reset** button on the R3 board. The bottom light strip will begin flashing to indicate a successful startup. .. note:: * If the bottom light strip shows a **flashing light of any color other than green**, your GalaxyRVR needs a firmware update. Please refer to :ref:`update_firmware`. .. raw:: html #. Connect your mobile device to the GalaxyRVR's WiFi network. * The network name (SSID) is ``GalaxyRVR`` and the password is ``12345678``. * If you see a warning stating "No Internet access," please choose the option to **"Stay connected."** .. image:: ../img/camera_lan.png :width: 500 #. In the app, tap **File** > **Open from device** to browse local files. .. image:: img/scratch_open_file.png :width: 600 #. Select a ``.sb3`` file to open it. .. image:: img/scratch_mobile_save.png :width: 400 #. Tap the the green flag icon to start the script. .. image:: img/scratch_run.png Examples --------------- **Basic Projects** These projects are the basic courses for controlling the GalaxyRVR with Mammoth Coding. They will guide you step by step on how to utilize GalaxyRVR. * ``3_move.sb3``: Control your GalaxyRVR's movement in real time using direction keys. * ``4_ultrasonic.sb3``: The rover moves forward and automatically avoids obstacles using the ultrasonic module. * ``5_ultra_animate_jump.sb3``: Creates an animated scene of the rover joyfully moving across the Martian surface. * ``6_ir_obstacle_avoid.sb3``: The rover moves forward and avoids obstacles using IR sensors. * ``7_ir_obstacle_avoid_animate.sb3``: Control the rover sprite to dodge rocks on the Martian surface by triggering IR sensors with your hands. * ``8_ir_ultrasonic_avoid.sb3``: The rover uses ultrasonic and IR sensors together to smoothly navigate around obstacles. * ``9_ir_ultrasonic_follow.sb3``: The rover follows you: it approaches when you stand in front, turns toward you when beside, and stops when you move away. * ``10_rgb.sb3``: Tap a colored ball to make the rover's RGB lights glow in that color. * ``10_rgb_animate.sb3``: The rover moves and changes light color according to the direction keys pressed. * ``1scratch_servo.sb3``: Use the arrow keys to adjust the rover's camera angle; click to reset its position. * ``1scratch_servo_stage.sb3``: Touch and drag the on-screen arrow to aim the rover's camera with smooth, real-time response. * ``12_camera.sb3``: View the live camera feed from your rover's perspective as it explores. * ``13_realtime_control.sb3``: Control your rover's movements and lights in real time through Scratch. **Fun Projects** These fun Scratch projects don't require the GalaxyRVR. You can find them all in the ``scratch_codes/fun/`` folder. * ``1_scratch_balloon.sb3``: Inflate the balloon by blocking the left IR sensor; don't let it burst or fall! * ``2_flappy_parrot.sb3``: Control the parrot's flight using your hand above the ultrasonic sensor to dodge bamboo poles. * ``3_shooting.sb3``: Aim and shoot targets using the obstacle avoidance module. * ``4_eat_apple.sb3``: Guide the beetle to the apple using hand gestures detected by the left IR sensor. * ``5_fishing.sb3``: Catch fish by blocking the left IR sensor at the right time. * ``6_sensitive_ball.sb3``: Move the ball up or down with your hand above the ultrasonic sensor; trigger sounds and lights when it touches a line. * ``7_tap_white_tile.sb3``: Tap black tiles using two IR sensors to score points — avoid the white ones!
