Quick Start with Arduino
In this chapter, you’ll learn how to **quickly open and run specific Arduino example codes** to make your GalaxyRVR perform various actions.
If you want to understand the code logic and programming principles behind these examples, please refer to the :ref:`programming_arduino` chapter.
How to Quickly Open an Arduino Example
In this example, we’ll demonstrate how to use the Arduino IDE to open an arduino example.
#. Start the GalaxyRVR.
* When using GalaxyRVR for the first time, it is recommended to fully charge the battery by plugging in a Type-C USB cable. Then, turn on the power.
.. raw:: html
* The ESP32-CAM and the Arduino board share the same RX (receive) and TX (transmit) pins. So, before uploading the code, you’ll need to first release the ESP32-CAM by slide this switch to right side to avoid any conflicts or potential issues.
.. image:: ../img/camera_upload.png
:width: 600
#. Connect your Arduino board to your computer using a USB cable.
#. Visit |link_download_arduino| and download the Arduino IDE for your operating system. Follow the installation prompts to complete setup.
.. image:: img/arduino_download_page.png
#. Download the example codes from the link below:
* :download:`GalaxyRVR Code File `
#. Unzip the downloaded file, navigate to ``galaxy-rvr-1.2.x\arduino_codes``.
.. image:: img/arduino_open_folder.png
#. Select an example code folder, navigate to that folder, then double-click the ``.ino`` file to open it in the Arduino IDE.
.. image:: img/arduino_open_file.png
#. In the Arduino IDE, select **Arduino Uno** as the board and choose the appropriate **port** for your device.
.. image:: img/arduino_choose_board.png
#. Click the **Upload** button (right-pointing arrow) to upload the code to your board.
.. image:: img/arduino_upload.png
.. note::
If you’re not familiar with the Arduino IDE, please refer to:
* :ref:`install_arduino_ide`
* :ref:`upload_sketch`
Examples
* ``5_car_move``: The rover moves forward, then backward, turns left and right, and finally stops.
* ``6_ir_avoid``: The rover avoids obstacles using IR sensors.
* ``7_ultrasonic_avoid``: The rover avoids obstacles using ultrasonic module.
* ``8_ultrasonic_ir_avoid``: The rover uses both IR and ultrasonic module to detect obstacles.
* ``8_ultrasonic_ir_follow``: The rover follows objects using IR and ultrasonic module.
* ``9_rgb_car_move``: Adds color indicators for movement: green for forward, red for backward, and yellow for turning left or right.
* ``10_servo_range``: The camera gimbal rotates from 0° to 180° using a for loop, and the current angle is displayed in the Serial Monitor.
* ``11_camera_view``: View the live video feed from the rover’s camera in a web browser. **SunFounder AI Camera** library is required.
* ``13_read_battery``: Monitors the battery voltage through code.
