Source code for sunfounder_voice_assistant.voice_assistant
from .llm import LLM
from .stt import STT
from .tts import Piper as TTS
from ._keyboard_input import KeyboardInput
from typing import Any, Callable, Optional
NAME = "Buddy"
""" Default assistant name """
WITH_IMAGE = True
""" Enable image, need to set up a multimodal language model """
TTS_MODEL = "en_US-ryan-low"
""" Default TTS model """
STT_LANGUAGE = "en-us"
""" Default STT language """
KEYBOARD_ENABLE = True
""" Enable keyboard input """
WAKE_ENABLE = True
""" Enable wake word """
WAKE_WORD = [f"hey {NAME.lower()}"]
""" Default wake word """
ANSWER_ON_WAKE = "Hi there"
""" Default answer on wake word, set empty to disable """
WELCOME = f"Hi, I'm {NAME}. Wake me up with: " + ", ".join(WAKE_WORD)
""" Default welcome message """
INSTRUCTIONS = f"You are a helpful assistant, named {NAME}."
""" Default set instructions """
[docs] class VoiceAssistant: """ Voice assistant class Args: llm (:class:`sunfounder_voice_assistant.llm.LLM`): Language model name (str, optional): Robot name, default is NAME with_image (bool, optional): Enable image, need to set up a multimodal language model, default is WITH_IMAGE tts_model (str, optional): Text-to-speech model, default is TTS_MODEL tts (object, optional): Pre-configured TTS engine instance. If provided, ``tts_model`` is ignored. stt_language (str, optional): Speech-to-text language, default is STT_LANGUAGE keyboard_enable (bool, optional): Enable keyboard input, default is KEYBOARD_ENABLE wake_enable (bool, optional): Enable wake word, default is WAKE_ENABLE wake_word (list, optional): Wake word, default is WAKE_WORD answer_on_wake (str, optional): Answer on wake word, default is ANSWER_ON_WAKE welcome (str, optional): Welcome message, default is WELCOME instructions (str, optional): Set instructions, default is INSTRUCTIONS disable_think (bool, optional): Disable think, default is False """ def __init__(self, llm: LLM, name: str = NAME, with_image: bool = WITH_IMAGE, tts_model: str = TTS_MODEL, tts: Optional[Any] = None, stt_language: str = STT_LANGUAGE, keyboard_enable: bool = KEYBOARD_ENABLE, wake_enable: bool = WAKE_ENABLE, wake_word: list = WAKE_WORD, answer_on_wake: str = ANSWER_ON_WAKE, welcome: str = WELCOME, instructions: str = INSTRUCTIONS, disable_think: bool = False, ) -> None: self.llm = llm self.name = name self.with_image = with_image self.wake_enable = wake_enable self.keyboard_enable = keyboard_enable self.wake_word = wake_word self.answer_on_wake = answer_on_wake self.welcome = welcome self.disable_think = disable_think self.instructions = instructions.format(name=name) self.tts = tts or TTS(model=tts_model) self.stt = STT(language=stt_language) self.llm.set_instructions(self.instructions) self.stt.set_wake_words(self.wake_word) self.waked = False self.running = False self.wake_waiting = False self.wait_wake_thread = None self.triggers = [] if self.wake_enable: self.add_trigger(self.trigger_wake_word) if self.keyboard_enable: self.keyboard_input = KeyboardInput() self.add_trigger(self.trigger_keyboard_input) if self.with_image: self.init_camera()
[docs] def before_listen(self) -> None: """ Before listen """ pass
[docs] def after_listen(self, stt_result: str) -> None: """ After listen Args: stt_result (str): Speech-to-text result """ pass
[docs] def before_think(self, text: str) -> None: """ Before think Args: text (str): Text to think """ pass
[docs] def after_think(self, text: str) -> None: """ After think Args: text (str): Text to think """ pass
[docs] def on_start(self) -> None: """ On start """ pass
[docs] def on_wake(self) -> None: """ On wake """ pass
[docs] def on_heard(self, text: str) -> None: """ On heard Args: text (str): Text heard """ pass
[docs] def parse_response(self, text: str) -> str: """ Parse response Args: text (str): Text to parse Returns: str: Parsed text """ return text
[docs] def add_trigger(self, trigger_function: Callable[[], tuple[bool, bool, str]]) -> None: """ Add trigger function Args: trigger_function (Callable[[], tuple[bool, bool, str]]): Trigger function """ self.triggers.append(trigger_function)
[docs] def before_say(self, text: str) -> None: """ Before say Args: text (str): Text to say """ pass
[docs] def after_say(self, text: str) -> None: """ After say Args: text (str): Text to say """ pass
[docs] def on_stop(self) -> None: """ On stop """ pass
[docs] def on_finish_a_round(self) -> None: """ On finish a round """ pass
[docs] def capture_image(self, path: str) -> None: """ Capture image Args: path (str): Path to save image """ if self.with_image and self.picam2: self.picam2.capture_file(path)
[docs] def trigger_wake_word(self) -> tuple[bool, bool, str]: """ Trigger wake word Returns: tuple[bool, bool, str]: Triggered, disable image, message """ triggered = False disable_image = False message = '' if self.stt.is_waked(): # listen self.stt.stop_listening() self.on_wake() if len(self.answer_on_wake) > 0: self.tts.say(self.answer_on_wake) print("Waked, Listening ...") message = self.listen() self.on_heard(message) self.waked = False triggered = True return triggered, disable_image, message
[docs] def trigger_keyboard_input(self) -> tuple[bool, bool, str]: """ Trigger keyboard input Returns: tuple[bool, bool, str]: Triggered, disable image, message """ triggered = False disable_image = False message = '' if self.keyboard_input.is_result_ready(): message = self.keyboard_input.result triggered = True return triggered, disable_image, message
[docs] def init_camera(self) -> None: """ Initialize camera """ from picamera2 import Picamera2 self.picam2 = Picamera2() self.picam2.configure(self.picam2.create_preview_configuration(main={"size": (640, 480)})) self.picam2.start()
[docs] def close_camera(self) -> None: """ Close camera """ if self.with_image and self.picam2: self.picam2.close()
[docs] def listen(self) -> str: """ Listen Returns: str: Speech-to-text result """ self.before_listen() stt_result = "" for result in self.stt.listen(stream=True): if self.running == False: break if result["done"]: print(f"heard: {result['final']}") stt_result = result['final'] else: print(f"heard: {result['partial']}", end="\r", flush=True) print("") if stt_result == False or stt_result == "": stt_result = None self.after_listen(stt_result) return stt_result
[docs] def think(self, text: str, disable_image: bool=False) -> str: """ Think Args: text (str): Text to think disable_image (bool, optional): Disable image, defaults to False Returns: str: LLM response """ self.before_think(text) if self.with_image and not disable_image: image_path = './img_input.jpeg' self.capture_image(image_path) else: image_path = None kwargs = { 'image_path': image_path, 'stream': True, } if self.disable_think: kwargs['think'] = False response = self.llm.prompt(text, **kwargs) llm_text = "" for next_word in response: if self.running == False: break if next_word: print(next_word, end="", flush=True) llm_text += next_word print('') result = llm_text.strip() self.after_think(result) return result
[docs] def main(self) -> None: """ Main loop """ self.running = True self.on_start() self.tts.say(self.welcome) # Main loop while self.running: triggered = False message = '' disable_image = False # Start listening wake words if wake enabled if self.wake_enable: self.stt.start_listening_wake_words() # Start keyboard input if self.keyboard_enable: self.keyboard_input.start() # Wait for triggers while self.running: for trigger in self.triggers: triggered, disable_image, message = trigger() if triggered: break if triggered: break time.sleep(0.01) # Stop listening wake words if wake enabled if self.wake_enable: self.stt.stop_listening() # Stop keyboard input if self.keyboard_enable: self.keyboard_input.stop() # think result = self.think(message, disable_image=disable_image) response_text = self.parse_response(result) # tts _status = False if response_text != '': self.before_say(response_text) self.tts.say(response_text) # on finish a round self.on_finish_a_round() # Wait a second before next round time.sleep(1)
[docs] def run(self) -> None: """ Run """ try: self.main() except KeyboardInterrupt: pass except Exception as e: print(f"\033[31mERROR: {e}\033[m") finally: self.running = False self.stt.close() if self.keyboard_enable: self.keyboard_input.stop() if self.with_image: self.close_camera() self.on_stop()
