.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 2. TTS with Piper and OpenAI ======================================================== In the previous lesson, we explored **Espeak** and **Pico2Wave**, two simple offline TTS engines on Raspberry Pi. Now, let’s take a big step forward and try two **more advanced TTS options** that offer **higher voice quality** and more flexibility: * **Piper** — a fast, neural network–based TTS engine that runs **completely offline** on Raspberry Pi. * **OpenAI TTS** — an online service that provides **very natural and human-like voices**, perfect for expressive speech. These engines will make your Fusion HAT+ sound more realistic and lifelike. 🚀 ---- .. _test_piper: 1. Testing Piper ------------------ Piper is an **offline neural TTS engine**, meaning you don’t need an internet connection once the model is installed. It supports multiple **languages** and **voices**, making it a powerful option for embedded speech. **Run the program** .. code-block:: bash cd ~/fusion-hat/examples sudo python3 tts_piper.py * The first time you run it, the selected **voice model** will be downloaded automatically. * You should then hear the Fusion HAT+ say: ``Hello! I'm Piper TTS.`` * You can switch voices or languages by calling ``set_model()`` with a different model name. **Code** .. code-block:: python from fusion_hat.tts import Piper tts = Piper() # List supported languages print(tts.available_countrys()) # List models for English (en_us) print(tts.available_models('en_us')) # Set a voice model (auto-download if not already present) tts.set_model("en_US-amy-low") # Say something tts.say("Hello! I'm Piper TTS.") **Code explanation:** * ``available_countrys()`` — Lists all supported languages. * ``available_models()`` — Lists available models for a specific language. * ``set_model()`` — Sets the voice model. If the model isn’t installed, it will download automatically. * ``say()`` — Converts text to speech and plays it immediately. 💡 **Tip:** Try different models to compare speed, clarity, and accents. Some models are lighter (faster), while others have higher fidelity. ---- 2. Testing OpenAI TTS ------------------------------- **Get and save your API Key** #. Go to |link_openai_platform| and log in. On the **API keys** page, click **Create new secret key**. .. image:: img/llm_openai_create.png #. Fill in the details (Owner, Name, Project, and permissions if needed), then click **Create secret key**. .. image:: img/llm_openai_create_confirm.png #. Once the key is created, copy it right away — you won't be able to see it again. If you lose it, you must generate a new one. .. image:: img/llm_openai_copy.png #. In your project folder (for example: ``/``), create a file called ``secret.py``: .. code-block:: bash cd ~/fusion-hat/examples sudo nano secret.py #. Paste your key into the file like this: .. code-block:: python # secret.py # Store secrets here. Never commit this file to Git. OPENAI_API_KEY = "sk-xxx" **Run the program** .. code-block:: bash cd ~/fusion-hat/examples sudo python3 tts_openai.py * The program will connect to OpenAI’s TTS service, and the Fusion HAT+ will speak using **natural, expressive voice output**. * You can change **voice styles** and add **instructions** to control tone and expression (e.g., sad, dramatic, playful). * This makes OpenAI TTS ideal for interactive robots, storytelling, or educational assistants. **Code** .. code-block:: python from fusion_hat.tts import OpenAI_TTS from secret import OPENAI_API_KEY # Export your OpenAI_API_KEY before running the script # export OPENAI_API_KEY="sk-proj-xxxxxx" tts = OpenAI_TTS(api_key=OPENAI_API_KEY) # tts.set_model('tts-1') tts.set_voice('alloy') tts.set_model('gpt-4o-mini-tts') msg = "Hello! I'm OpenAI TTS." print(f"Say: {msg}") tts.say(msg) msg = "with instructions, I can say word sadly" instructions = "say it sadly" print(f"Say: {msg}, with instructions: '{instructions}'") tts.say(msg, instructions=instructions) msg = "or say something dramaticly." instructions = "say it dramaticly" print(f"Say: {msg}, with instructions: '{instructions}'") tts.say(msg, instructions=instructions) **Code explanation:** * ``OpenAI_TTS()`` — Initializes the OpenAI TTS engine using your API key. * ``set_model()`` — Selects the TTS model (e.g., ``gpt-4o-mini-tts``). * ``set_voice()`` — Chooses a specific voice (e.g., ``alloy``). * ``say(text)`` — Converts the text to speech and plays it. * ``say(text, instructions=...)`` — Adds **expressive tone instructions**, allowing you to control the style of speech dynamically. **Example:** - “say it sadly” → soft, emotional tone - “say it dramatically” → bold and expressive delivery - “say it excitedly” → enthusiastic tone ---- Troubleshooting ------------------- * **No module named 'secret'** This means ``secret.py`` is not in the same folder as your Python file. Move ``secret.py`` into the same directory where you run the script, e.g.: .. code-block:: bash ls ~/ # Make sure you see both: secret.py and your .py file * **OpenAI: Invalid API key / 401** * Check that you pasted the full key (starts with ``sk-``) and there are no extra spaces/newlines. * Ensure your code imports it correctly: .. code-block:: python from secret import OPENAI_API_KEY * Confirm network access on your Pi (try ``ping api.openai.com``). * **OpenAI: Quota exceeded / billing error** * You may need to add billing or increase quota in the OpenAI dashboard. * Try again after resolving the account/billing issue. * **Piper: tts.say() runs but no sound** * Make sure a voice model is actually present: .. code-block:: bash ls ~/.local/share/piper/voices * Confirm your model name matches exactly in code: .. code-block:: python tts.set_model("en_US-amy-low") * Check the audio output device/volume on your Pi (``alsamixer``), and that speakers are connected and powered. * **ALSA / sound device errors (e.g., “Audio device busy” or “No such file or directory”)** * Close other programs using audio. * Reboot the Pi if the device stays busy. * For HDMI vs. headphone jack output, select the correct device in Raspberry Pi OS audio settings. * **Permission denied when running Python** * Try with ``sudo`` if your environment requires it: .. code-block:: bash sudo python3 tts_piper.py Comparison of TTS Engines ------------------------- .. list-table:: Feature comparison: Espeak vs Pico2Wave vs Piper vs OpenAI TTS :header-rows: 1 :widths: 18 18 20 22 22 * - Item - Espeak - Pico2Wave - Piper - OpenAI TTS * - Runs on - Built-in on Raspberry Pi (offline) - Built-in on Raspberry Pi (offline) - Raspberry Pi / PC (offline, needs model) - Cloud (online, needs API key) * - Voice quality - Robotic - More natural than Espeak - Natural (neural TTS) - Very natural / human-like * - Controls - Speed, pitch, volume - Limited controls - Choose different voices/models - Choose model and voices * - Languages - Many (quality varies) - Limited set - Many voices/languages available - Best in English (others vary by availability) * - Latency / speed - Very fast - Fast - Real-time on Pi 4/5 with “low” models - Network-dependent (usually low latency) * - Setup - Minimal - Minimal - Download ``.onnx`` + ``.onnx.json`` models - Create API key, install client * - Best for - Quick tests, basic prompts - Slightly better offline voice - Local projects with better quality - Highest quality, rich voice options
