.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. πŸ‘‰ Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 3. STT with Vosk (Offline) ============================================== Vosk is a lightweight speech-to-text (STT) engine that supports many languages and runs fully **offline** on Raspberry Pi. You only need internet access once to download a language model. After that, everything works without a network connection. In this lesson, we will: * Check the microphone on Raspberry Pi. * Install and test Vosk with a chosen language model. 1. Check Your Microphone -------------------------- Before using speech recognition, make sure your USB microphone works correctly. #. List available recording devices: .. code-block:: bash arecord -l Look for a line like ``card 1: ... device 0``. #. Record a short sample (replace ``1,0`` with the numbers you found): .. code-block:: bash arecord -D plughw:1,0 -f S16_LE -r 16000 -d 3 test.wav * Example: if your device is ``card 2, device 0``, use: .. code-block:: bash arecord -D plughw:2,0 -f S16_LE -r 16000 -d 3 test.wav #. Play it back to confirm the recording: .. code-block:: bash aplay test.wav #. Adjust microphone volume if needed: .. code-block:: bash alsamixer * Press **F6** to select your USB microphone. * Find the **Mic** or **Capture** channel. * Make sure it is not muted (**[MM]** means mute, press ``M`` to unmute β†’ should show **[OO]**). * Use ↑ / ↓ arrow keys to change the recording volume. .. _test_vosk: 2. Test Vosk -------------------------- **Run the program** .. code-block:: bash cd ~/fusion-hat/examples sudo python3 stt_vosk_stream.py The first time you run this code with a new language, Vosk will: * **Automatically download the language model** (by default, the small version). * **Print out the list of supported languages**. * Start **listening** for audio input through the microphone. You’ll see something like this in the terminal: .. code-block:: text vosk-model-small-en-us-0.15.zip: 100%|β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 39.3M/39.3M [00:05<00:00, 7.85MB/s] ['ar', 'ar-tn', 'ca', 'cn', 'cs', 'de', 'en-gb', 'en-in', 'en-us', 'eo', 'es', 'fa', 'fr', 'gu', 'hi', 'it', 'ja', 'ko', 'kz', 'nl', 'pl', 'pt', 'ru', 'sv', 'te', 'tg', 'tr', 'ua', 'uz', 'vn'] Say something This means: * The model file (``vosk-model-small-en-us-0.15``) has been downloaded. * The list of supported languages has been printed. * The system is now listening β€” say something into the Fusion HAT+ microphone, and the recognized text will appear in the terminal. **Tips:** * Keep the microphone about **15–30 cm** away for better accuracy. * Choose a **model that matches your language and accent**. * Use a quiet environment to improve recognition. **Code** .. code-block:: python from fusion_hat.stt import Vosk as STT stt = STT(language="en-us") while True: print("Say something") for result in stt.listen(stream=True): if result["done"]: print(f"final: {result['final']}") else: print(f"partial: {result['partial']}", end="\r", flush=True) **Code explanation:** * ``stt.listen(stream=True)`` β€” Starts streaming speech recognition and yields intermediate results as you speak. * ``result["partial"]`` β€” Displays the **real-time recognized text** (updated continuously). * ``result["final"]`` β€” Displays the **final recognized sentence** when you stop speaking. * The loop runs continuously, allowing **hands-free real-time transcription**. Tip: This streaming mode is perfect for **voice assistants**, **command control**, or **live transcription**. Troubleshooting ----------------- * **No such file or directory (when running `arecord`)** You may have used the wrong card/device number. Run: .. code-block:: bash arecord -l and replace ``1,0`` with the numbers shown for your USB microphone. * **Recorded file has no sound** Open the mixer and check the microphone volume: .. code-block:: bash alsamixer * Press **F6** to select your USB mic. * Make sure **Mic/Capture** is not muted (**[OO]** instead of **[MM]**). * Increase the level with ↑. * **Vosk does not recognize speech** * Make sure the **language code** matches your model (e.g. ``en-us`` for English, ``zh-cn`` for Chinese). * Keep the microphone 15–30 cm away and avoid background noise. * Speak clearly and slowly. * **High latency / slow recognition** * The default auto-download is a **small model** (faster, but less accurate). * If it’s still slow, close other programs to free CPU.
