Always displaying “Unknown COMxx”?
When plugging the ESP32 into the computer, the Arduino IDE often displays Unknown COMxx. Why does this happen?
../_images/unknown_device.png
This is because the USB driver for ESP32 is different from the regular Arduino Boards. The Arduino IDE can’t automatically recognize this board.
In such a scenario, you need to manually select the correct board by following these steps:
  1. Click on “Select the other board and port”.
    ../_images/unknown_select.png
  2. In the search, type “esp32 dev module”, then select the board that appears. Afterward, select the correct port and click OK.
    ../_images/unknown_board.png
  3. Now, you should be able to see your board and port in this quick view window.
    ../_images/unknown_correct.png
