Video 50: Temperature and Humidity Monitoring with Adafruit IO
Learn how to set up an ESP32 IoT project using MQTT and Adafruit IO, from hardware setup to code uploading and dashboard creation.
  • ESP32 Starter Kit Introduction: Overview of the components needed for the project.
  • MQTT Explanation: Understand the significance of MQTT in IoT applications.
  • Adafruit IO Setup: Step-by-step guide to creating an account and dashboard on Adafruit IO.
  • Hardware Wiring Guide: Detailed instructions on wiring the ESP32, DHT11 temperature sensor, and LED.
  • Arduino Code Walkthrough: Explanation of the code including library installation, Wi-Fi setup, and MQTT connection.
  • Project Demonstration: Watch the process of uploading the code, monitoring data on Adafruit IO dashboard, and remotely controlling the LED.
Video
Related On-line Tutorials
  • ar_adafruit_io
