Video 26: Using Joystick
Learn how to wire a joystick to an ESP32 microcontroller, covering detailed explanations, wiring configurations, code implementation, and testing.
  • Joystick components: Understand the components of the joystick, including variable resistors and switches.
  • Wiring configuration: Follow step-by-step instructions on how to wire the joystick to the ESP32 microcontroller, covering connections for analog pins, switches, power, and ground.
  • Code implementation: Learn how to write and upload code to the ESP32 microcontroller using the Arduino IDE, including code for reading joystick values and taking actions based on those values.
  • Testing and troubleshooting: Discover how to test the joystick setup using the serial monitor and troubleshoot common issues, such as incorrect wiring or code errors.
Video
Related On-line Tutorials
  • ar_joystick
