IMU Module (10-Axis)
Different versions of this kit may use different IMU modules. Please select the appropriate tutorial based on the version of the kit you have. If you have a 10-axis IMU module, please refer to this tutorial. If you have a GY-87 module, please refer to IMU Module (GY-87).
The 10-Axis IMU (Inertial Measurement Unit) module combines multiple sensors to provide comprehensive motion and environmental data. It integrates a barometric pressure sensor (SPL06_001) for altitude measurement, a 6-axis motion sensor (SH3001) for acceleration and rotation, and a 3-axis magnetometer (QMC6310) for compass heading. This sophisticated module is ideal for robotics, navigation systems, and motion-tracking applications.
Fritzing Circuit
../_images/imu_bb.png
Install library
To install the library, use the Arduino Library Manager.
  • Search for “SunFounder_IMU” and install
    ../_images/09-add_lib_tip_imu.png
Calibration
Before using the IMU module, it is recommended to perform calibration to ensure the accuracy of sensor data. The following are the calibration steps:
  • Open the file 09-imu_calibration.ino under the path of elite-explorer-kit-main\basic_project\09-imu_calibration directly.
After running this code, open the Serial Monitor and you will see the sensor data output. It is typically in the following format:
const float ACCEL_BIAS[3] = {0.0, 0.0, 0.0};
const float ACCEL_SCALE[3] = {1.0, 1.0, 1.0};
const float GYRO_BIAS[3] = {0.0, 0.0, 0.0};
const float GYRO_SCALE[3] = {1.0, 1.0, 1.0};
const float MAG_BIAS[3] = {0.0, 0.0, 0.0};
const float MAG_SCALE[3] = {1.0, 1.0, 1.0};
Copy this data.
Run the Code
Open the file 09-imu.ino under the path of elite-explorer-kit-main\basic_project\09-imu directly.
Go to the calibration_data.h page in the project, paste the data you just copied into the calibration_data.h file, replacing the original data.
../_images/imu_cali_data.png
Switch back to the 09-imu.ino page and upload the code to your Arduino Uno R4 board.
09-imu.ino
 1#include "SunFounder_IMU.hpp"
 2#include "calibration_data.h"
 4#include "Wire.h"
 6// For Arduino UNO R4, use Wire1 as I2C bus
 7#define Wire Wire1
 8// For ESP32, you may need to set the I2C pins
 9// #define SDA 43
10// #define SCL 44
11
12SunFounder_IMU imu(&Wire);
13
14void setup() {
15  Serial.begin(115200);
16  while (!Serial) {
17    delay(100);
18  }
19  // For ESP32, you may need to set the I2C pins
20  // Wire.begin(SDA, SCL);
21  Wire.begin();
22  imu.begin();
23  imu.set_accel_bias(ACCEL_BIAS);
24  imu.set_accel_scale(ACCEL_SCALE);
25  imu.set_gyro_bias(GYRO_BIAS);
26  imu.set_gyro_scale(GYRO_SCALE);
27  imu.set_magnetometer_bias(MAG_BIAS);
28  imu.set_magnetometer_scale(MAG_SCALE);
29
30  // Change these if necessary
31  // imu.set_gravity(GRAVITY);
32  // imu.set_barometer_pressure_offset(BARO_PRESSURE_OFFSET);
33  // imu.set_barometer_sealevel_pressure(BARO_SEALEVEL_PRESSURE);
34}
35
36void loop() {
37  imu.read();
38  if (imu.is_motion_sensor_found()) {
39    Vector3f accel = imu.get_accel();
40    Vector3f gyro = imu.get_gyro();
41
42    Serial.print("Accel: ");
43    Serial.print(accel.x);
44    Serial.print(", ");
45    Serial.print(accel.y);
46    Serial.print(", ");
47    Serial.println(accel.z);
48    Serial.print("Gyro: ");
49    Serial.print(gyro.x);
50    Serial.print(", ");
51    Serial.print(gyro.y);
52    Serial.print(", ");
53    Serial.println(gyro.z);
54  }
55  if (imu.is_magnetometer_found()) {
56    Vector3f magnetometer = imu.get_magnetometer();
57    float azimuth = imu.get_azimuth();
58    Serial.print("Magnetometer: ");
59    Serial.print(magnetometer.x);
60    Serial.print(", ");
61    Serial.print(magnetometer.y);
62    Serial.print(", ");
63    Serial.println(magnetometer.z);
64    Serial.print("Azimuth: ");
65    Serial.println(azimuth);
66  }
67  if (imu.is_barometer_found()) {
68    float temperature = imu.get_temperature();
69    float pressure = imu.get_pressure();
70    float altitude = imu.get_altitude();
71
72    Serial.print("Temperature: ");
73    Serial.println(temperature);
74    Serial.print("Pressure: ");
75    Serial.println(pressure);
76    Serial.print("Altitude: ");
77    Serial.println(altitude);
78  }
79  delay(1000);
80}
After the code is successfully uploaded to your Arduino Uno R4, the Serial Monitor will come to life, continuously printing out sensor data from the 10-Axis IMU module.
../_images/imu_reading.png
