Arduino Program Structure
Let’s take a look at the new sketch file. Although it has a few lines of code itself, it is actually an “empty” sketch. Uploading this sketch to the development board will cause nothing to happen.
// put your main code here, to run repeatedly:
If we remove setup() and loop() and make the sketch a real blank file, you will find that it does not pass the verification.
They are the equivalent of the human skeleton, and they are indispensable.
During sketching, setup() is run first, and the code inside it (inside {}) is run after the board is powered up or reset and only once.
loop() is used to write the main feature, and the code inside it will run in a loop after setup() is executed.
To better understand setup() and loop(), let’s use four sketches. Their purpose is to make the on-board LED of the Arduino blink. Please run each experiment in turn and record their specific effects.
Sketch 1: Make the on-board LED blink continuously.
pinMode(13,OUTPUT);
digitalWrite(13,HIGH);
delay(500);
digitalWrite(13,LOW);
delay(500);
Sketch 2: Make the on-board LED blink only once.
pinMode(13,OUTPUT);
delay(500);
delay(500);
Sketch 3: Make the on-board LED blink slowly once and then blink quickly.
pinMode(13,OUTPUT);
delay(1000);
delay(1000);
delay(200);
delay(200);
Sketch 4: Report an error.
pinMode(13,OUTPUT);
delay(1000);
delay(1000);
With the help of these sketches, we can summarize several features of setup-loop.
loop()will be run repeatedly after the board is powered up.setup()will run only once after the board is powered up.After the board is powered up,
setup()will run first, followed byloop().The code needs to be written within the
{}scope ofsetup()orloop(), out of the framework will be an error.
Statements such as digitalWrite(13,HIGH) are used to control the on-board LED, and we will talk about their usage in detail in later chapters.
