.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Lesson 5 Controlling LED by Button ========================================== **Introduction** --------------------- In this lesson, we will learn how to turn an LED on or off by a button. **Newly Added Components** ----------------------------------- .. image:: media_pi/image209.png :width: 800 :align: center **Principle** --------------------- Button Button is a common component used to control electronic devices. It is usually used as switch to connect or break circuits. Although buttons come in a variety of sizes and shapes, the one used here is a 6mm mini-button as shown in the following pictures. Two pins on the same side are connected, which is shown below: .. image:: media_pi/image102.png :width: 150 :align: center The symbol shown as below is usually used to represent a button in circuits. .. image:: media_pi/image210.png :width: 400 :align: center When the button is pressed, the 4 pins are connected, thus closing the circuit. **Schematic Diagram** -------------------------- When the button is pressed once, pin 32 is 3.3V (HIGH). Set the pin 11(integrated with an LED) as high level by programming at the same time. Then press the button again and set pin 11 to Low. So we will see the LED light on and off alternately as the button is pressed many times. .. image:: media_pi/image211.png :width: 800 :align: center .. image:: media_pi/image265.png :width: 800 :align: center **Build the Circuit** ----------------------------- .. image:: media_pi/image267.png :width: 800 :align: center **For C Language Users** ---------------------------- **Command** ^^^^^^^^^^^^ **1.** Go to the folder of the code. .. raw:: html .. code-block:: cd /home/pi/electronic-kit/for-raspberry-pi/c/Lesson_5_Controlling_Led_by_Button **2.** Compile the code. .. raw:: html .. code-block:: gcc 5_Button.c -lwiringPi **3.** Run the executable file. .. raw:: html .. code-block:: sudo ./a.out When you press the button for the first time, the LED lights up. When the button is pressed again, the LED lights off. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`C code is not working?`. **Code** ^^^^^^^^^^^^^^^ .. code-block:: C #include #include #define LedPin 0 #define ButtonPin 26 int state = 0; int main(void){ // When initialize wiring failed, print message to screen if(wiringPiSetup() == -1){ printf("setup wiringPi failed !"); return 1; } pinMode(LedPin, OUTPUT); pinMode(ButtonPin, INPUT); pullUpDnControl(ButtonPin, PUD_DOWN); while(1){ // Indicate that button has pressed down if(digitalRead(ButtonPin) == 1) { delay(10); if(digitalRead(ButtonPin) == 1) { state ++; if(state%2 == 1) { digitalWrite(LedPin,HIGH); delay(100); } if(state%2 == 0) { digitalWrite(LedPin,LOW); delay(100); } } } } return 0; } **Code Explanation** ^^^^^^^^^^^^^^^^^^^^^^ .. code-block:: C 6. int state = 0; Define a variable **state** to record the number of times it is pressed and the initial number of times is **0**. .. code-block:: C 15. pinMode(LedPin, OUTPUT); 16. pinMode(ButtonPin, INPUT); Set the LedPin to **OUTPUT** mode, ButtonPin to **INPUT** mode. .. code-block:: C 17. pullUpDnControl(ButtonPin, PUD_DOWN); When the button is not pressed, ButtonPin is in suspension at which time the read value is changing. To enable ButtonPin to output a stable low level, **PUD_DOWN** is added to the code, keeping ButtonPin at the forced pull-down state till the button is pressed. .. code-block:: C 21. if(digitalRead(ButtonPin) == 1) 22. { 23. delay(10); 24. if(digitalRead(ButtonPin) == 1) 25. { Usually the buttons we use are mechanical buttons, so in the process of pressing down and releasing, there will be no direct change from 0 to 1, but will be more than 10ms of level jitter. In order to ensure that the program only responds to the button once when it is closed or broken, the jitter elimination of the button must be carried out. An **if** function is used to detect whether the button is pressed. When the signal of the button is pressed is detected, a delay of 10ms is used to eliminate the possibility of false judgment, and another **if** function is used to detect again. If both **if** conditions are met, confirm that it is a button press, and then execute the program in the **if**. .. code-block:: C 26. state ++; If the button is pressed, the number of times it is pressed is increased by one. (state ++ is the same as state = state+1). .. code-block:: C 27. if(state%2 == 1) 28. { 29. digitalWrite(LedPin,HIGH); 30. delay(100); 31. } % is a modulo operator in C language; state%2 is that state is divided by 2 to return the remainder. If state=17, then state%2 =1. Here, determine whether state%2 is equal to 1. If it is, it means that the number of times of pressing the button is a singular number, and then turn on the LED. .. code-block:: C 32. if(state%2 == 0) 33. { 34. digitalWrite(LedPin,LOW); 35. delay(100); 36. } Here, judge whether state%2 is equal to 0. If so, it means that the number of times the button is pressed is an even number, and then turn off the LED. **For Python Language Users** --------------------------------- **Command** ^^^^^^^^^^^^^^^^ **1.** Go to the folder of the code. .. raw:: html .. code-block:: cd /home/pi/electronic-kit/for-raspberry-pi/python **2.** Run the code. .. raw:: html .. code-block:: sudo python3 5_Button.py When you press the button for the first time, the LED lights up. When the button is pressed again, the LED lights off. **Code** ^^^^^^^^^^^^^^^^ .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``electronic-kit/for-raspberry-pi/python``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python import RPi.GPIO as GPIO import time LedPin = 17 BtnPin = 12 Led_status = False # Define a setup function for some setup def setup(): GPIO.setmode(GPIO.BCM) GPIO.setup(BtnPin, GPIO.IN) GPIO.setup(LedPin, GPIO.OUT, initial=GPIO.LOW) GPIO.add_event_detect(BtnPin, GPIO.FALLING, callback=swLed) # Define a callback function for button callback def swLed(ev=None): global Led_status Led_status = not Led_status GPIO.output(LedPin, Led_status) # Define a main function for main process def main(): while True: # Don't do anything. time.sleep(1) # Define a destroy function for clean up everything after # the script finished def destroy(): # Turn off LED GPIO.output(LedPin, GPIO.LOW) # Release resource GPIO.cleanup() # If run this script directly, do: if __name__ == '__main__': setup() try: main() # When 'Ctrl+C' is pressed, the child program # destroy() will be executed. except KeyboardInterrupt: destroy() **Code Explanation** ^^^^^^^^^^^^^^^^^^^^^^^ .. code-block:: 6. Led_status = False Set a variable **Led_status** to record the current status of the LED; when Led_status is **True**, it indicates that the current lamp is in bright state; when Led_status is **False**, it means that the light is off. .. code-block:: 11. GPIO.setup(BtnPin, GPIO.IN) Set **BtnPin** as input mode to read the state of the button to determine whether to execute the corresponding program. Note that when **GPIO.setup** sets the pin to input mode, then there is no need to set the initial value. .. code-block:: 12. GPIO.setup(LedPin, GPIO.OUT, initial=GPIO.LOW) Specify an initial value for your output channel. Here the LED is the output component, so we set **LedPin** to **GPIO.OUT** mode. Then initialize the state of LED to **GPIO.LOW** which means that the light is off. .. code-block:: 13. GPIO.add_event_detect(BtnPin, GPIO.FALLING, callback=swLed) The **event_detected()** function is designed to be used in a loop with other things, but unlike polling it is not going to miss the change in state of an input while the CPU is busy working on other things. Set up a falling detect on BtnPin, when the BtnPin pin is detected to change from high level to low level, **swLed** function is called. .. code-block:: 13.def swLed(ev=None): 14. global Led_status 15. Led_status = not Led_status 16. GPIO.output(LedPin, Led_status) RPi.GPIO runs a second thread for callback functions. This means that callback functions can be run at the same time as your main program, in immediate response to an edge. Define a callback function for button callback, execute the function after the callback of the interrupt. When this function is executed, the state of the LED is firstly reversed(If **True**, make it **False**, and vice versa). Then input the function to LedPin. And "**ev** = **None**" means that if no parameter is passed when calling **swLed**, take **None** as the default value of **ev**. **Phenomenon Picture** ---------------------------- .. image:: media_pi/image107.jpeg :width: 800 :align: center
