.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Lesson 18 Answer Machine ============================ **Introduction** ----------------------- In quiz shows, especially entertainment activities (e.g. competitive answering activities), organizers often apply a buzzer system in order to accurately, fairly and visually determine the seat number of a responder. Now the system can illustrate the accuracy and equity of the judgment by data, which improves the entertainment. At the same time, it is more fair and just. In this lesson, we will use some buttons, buzzers, and LEDs to make a quiz buzzer system. **Components** ----------------- .. image:: media_arduino/image171.png :width: 800 :align: center .. image:: media_arduino/image200.png :width: 800 :align: center **Experimental Principle** ----------------------------- Button 1, 2 and 3 are answer buttons, and button 4 is the reset button. If button 1 is pressed first, the buzzer will beep, the corresponding LED will light up and all the other LEDs will go out. If you want to start another round, press button 4 to reset. The schematic diagram: .. image:: media_arduino/image155.png :width: 800 :align: center **Experimental Procedures** **Step 1:**\ Build the circuit **Step 2:** Open the code file. **Step 3:** Select the Board and Port. **Step 4:** Upload the sketch to the board. .. image:: media_arduino/image226.png :align: center Now, first press button 4 to start. If you press button 1 first, you will see the corresponding LED light up and the buzzer will beep. Then press button 4 again to reset before you press other buttons. .. image:: media_arduino/image157.jpeg :width: 800 :align: center **Code** --------------------- The code for this experiment may be a bit long. But the syntax issimple. Let's see. **Workflow:** Read the state of button 4, if button 4 is pressed, theLED on pin 10 is illuminated while reading the state of the remaining buttons. If one of the buttons is detected to be pressed, the buzzer beeps and lights the corresponding LED until button 4 is pressed again. .. raw:: html **Code Analysis** **18-1** **loop() function** ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ .. code-block:: arduino b4State = digitalRead(button4); // read the value of button4 to see if it was pressed. Serial.println(b4State); // print it value. //when button4 pressed if(b4State == 0) // if the button4 is pressed, the b4State=0 { if(b4State == 0) /*confirm that the button4 is pressed. One pin of the button is connected to pin 9, the other pin is connected to GND, and when the button is pressed, pin 9 is pulled low.*/ { flag = 1; // if so,flag is 1 digitalWrite(LED4, HIGH); // turn the reset LED on delay(200); // delay 200ms } } if(1 == flag) { // read the state of other buttons b1State = digitalRead(button1); b2State = digitalRead(button2); b3State = digitalRead(button3); // If the button1 press the first if(b1State == 0) // if button1 is pressed { flag = 0; // flag equals to 0 digitalWrite(LED4, LOW); Alarm(); // buzzer sound digitalWrite(LED1,HIGH); // turn the LED1 on only digitalWrite(LED2,LOW); digitalWrite(LED3,LOW); while(digitalRead(button4)); // detect the button4,if pressed,out of the while loop } ... Use the same way to detect the button2 and button3, if one of the buttons is detected to be pressed, the buzzer beeps and lights the corresponding LED until button 4 is pressed again. **Code Analysis** **18-2** **Alarm() function** ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ .. code-block:: arduino void Alarm() { for(int i=0;i<100;i++) { digitalWrite(buzzerPin,HIGH); // the buzzer sound delay(2); // delay 2ms digitalWrite(buzzerPin,LOW); // without sound delay(2); // when delay time changed,the frequency changed } } The alarm() function is to set the buzzer to beep. You can change the frequency and time of the buzzer sound.
