.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
Lesson 12 Passive Buzzer
**Introduction**
In this lesson, we will learn how to make a passive buzzer to play
music.
**Newly Added Components**
.. image:: media_pi/image227.png
:width: 800
:align: center
**Schematic Diagram**
The base pin(b pin) of the transistor is connected to pin11, the
collector pin(c pin) to the cathode pin of the buzzer, and the emitter
pin(e pin) to GND. The anode of the buzzer is connected to 5 v power
supply. When pin11 inputs high voltage, the transistor will be switched
on, and the collector will output low level. When there is a level
difference between the two pins of the buzzer, the buzzer rings. When
pin11 inputs low power level, the transistor is cut off, and the
collector is at high level, and both ends of the buzzer are at high
level, so the buzzer is silent.
.. image:: media_pi/image228.png
:width: 800
:align: center
.. image:: media_pi/image256.png
:width: 800
:align: center
**Build the Circuit**
.. image:: media_pi/image147.png
:width: 800
:align: center
**For C Language Users**
**Command**
**1.** Go to the folder of the code.
.. raw:: html
.. code-block::
cd /home/pi/electronic-kit/for-raspberry-pi/c/Lesson_12_PassiveBuzzer
**2.** Compile the code.
.. raw:: html
.. code-block::
gcc 12_PassiveBuzzer.c -lwiringPi
**3.** Run the executable file.
.. raw:: html
.. code-block::
Now, the buzzer automatically plays music on a loop.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`C code is not working?`.
**Code**
.. code-block:: C
#include
#include
#include
#define BuzPin 0
#define CM1 262
#define CM2 294
#define CM3 330
#define CM4 350
#define CM5 393
#define CM6 441
#define CM7 495
#define CH1 525
#define CH2 589
#define CH3 661
#define CH4 700
#define CH5 786
#define CH6 882
#define CH7 990
int song[] = {CH5,CH2,CM6,CH2,CH3,CH6,0,CH3,CH5,CH3,CM6,CH2,0};
int beat[] = {1,1,1,1,1,1,2,1,1,1,1,1,3};
int main(void)
int i, j;
if(softToneCreate(BuzPin) == -1){
printf("setup softTone failed !");
printf("music is being played...\n");
for(int i=0;i
WiringPi includes a software-driven sound handler capable
of outputting a simple tone/square wave signal on any of
the Raspberry Pi’s GPIO pins. To maintain a low CPU usage,
the minimum pulse width is 100μS. That gives a maximum frequency
of 1/0.0002 = 5000Hz. Within these limitations, simple tones on a
high impedance speaker or piezo sounder is possible.
.. code-block:: C
#define CM1 262
#define CM2 294
#define CM3 330
#define CM4 350
#define CM5 393
#define CM6 441
#define CM7 495
These frequencies of each note are as shown. CM refers to
middle note, CH high note, 1-7 correspond to the notes C, D, E, F, G, A, B.
.. code-block:: C
23.int song[] = {CH5,CH2,CM6,CH2,CH3,CH6,0,CH3,CH5,CH3,CM6,CH2,0};
24.int beat[] = {1,1,1,1,1,1,2,1,1,1,1,1,3};
Define a section of music and the corresponding beat.
The number in **beat[]** refers to the beat of each note in the
**song** (0.5s for each beat).
.. code-block:: C
35. if(softToneCreate(BuzPin) == -1){
**softToneCreate( )** creates a software controlled tone pin.
You can use any GPIO pin and the pin numbering will be that
of the **wiringPiSetup()** function you used. The return value is 0
for success. This is used to determine whether it is successful
for the software to control tone pin; if it fails, it will not execute the program.
.. code-block:: C
42. for(int i=0;i
.. code-block::
cd /home/pi/electronic-kit/for-raspberry-pi/python
**2.** Run the code.
.. raw:: html
.. code-block::
sudo python3 12_PassiveBuzzer.py
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``electronic-kit/for-raspberry-pi/python``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
import RPi.GPIO as GPIO
Buzzer = 17
CL = [0, 131, 147, 165, 175, 196, 211, 248] # Frequency of Low C notes
CM = [0, 262, 294, 330, 350, 393, 441, 495] # Frequency of Middle C notes
CH = [1, 525, 589, 661, 700, 786, 882, 990] # Frequency of High C notes
song = [ CH[5], CH[2], CM[6], CH[2], CH[3], CH[6],CH[0], CH[3], # Notes of song
CH[5], CH[3], CM[6], CH[2],CH[0]]
beat = [ 1,1,1,1,1,1,2,1,1,1,1,1,3 ]
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(Buzzer, GPIO.OUT)
global Buzz
def loop():
print ('\n Playing song...')
for i in range(1, len(song)):
if song[i] == 1 :
time.sleep(beat[i] *0.25)
Buzz = GPIO.PWM(Buzzer, song[i])
Buzz.start(50)
time.sleep(beat[i] * 0.25)
Buzz.stop()
time.sleep(1) # Wait a second for next song.
def destory():
Buzz.stop()
GPIO.output(Buzzer, LOW)
GPIO.cleanup()
setup()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destory()
**Code Explanation**
.. code-block::
6.CL = [0, 131, 147, 165, 175, 196, 211, 248]
7.CM = [0, 262, 294, 330, 350, 393, 441, 495]
8.CH = [1, 525, 589, 661, 700, 786, 882, 990]
These are the frequencies of each note. The first 0 is to
skip **CL[0]** so that the number **CL[1]-CL[7]** corresponds to the
CDEFGAB of the note.
.. code-block::
10.int song[] = {CH5,CH2,CM6,CH2,CH3,CH6,0,CH3,CH5,CH3,CM6,CH2,0};
13.int beat[] = {1,1,1,1,1,1,2,1,1,1,1,1,3};
Define a section of music and the corresponding beats.
in the **song** (0.5s for each beat).
.. code-block::
29. Buzz = GPIO.PWM(Buzzer, song[i])
30. Buzz.start(50)
Define pin Buzzer as PWM pin, then set its frequency to 786(song[0])
and **Buzz.start(50)** is used to run PWM. What’s more,
set the duty cycle to 50%.
.. code-block::
22. def loop():
23. while True:
24. print ('\n Playing song...')
25. for i in range(1, len(song)):
26. if song[i] == 1 :
27. time.sleep(beat[i] *0.25)
28. else:
30. Buzz.start(50)
31. time.sleep(beat[i] * 0.25)
32. Buzz.stop()
33. time.sleep(1)
Play music in the while loop. As i increases gradually, the buzzer
plays following the note in song[].
**Phenomenon Picture**
.. image:: media_pi/image148.jpeg
:width: 800
:align: center
