.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Lesson 10 Active Buzzer ================================================== **Introduction** ---------------------- A buzzer is a great tool in your experiments whenever you want to make sounds. **Newly Added Components** ----------------------------- .. image:: media_pi/image223.png :width: 800 :align: center **Principle** ------------------ As a type of electronic buzzer with an integrated structure, buzzers, which are supplied by DC power, are widely used in computers, printers, photocopiers, alarms, electronic toys, automotive electronic devices, telephones, timers and other electronic products or voice devices. Buzzers can be categorized as active and passive ones (see the following picture). Turn the buzzer so that its pins are facing up, and the buzzers with a green circuit board is a passive buzzer, while the one enclosed with a black tape is an active one. The difference between an active buzzer and a passive buzzer: .. image:: media_pi/image139.png :width: 400 :align: center An active buzzer has a built-in oscillating source, so it will make sounds when electrified. But a passive buzzer does not have such source, so it will not tweet if DC signals are used; instead, you need to use square waves whose frequency is between 2K and 5K to drive it. The active buzzer is often more expensive than the passive one because of multiple built-in oscillating circuits. In this experiment, we use an active buzzer. **Schematic Diagram** -------------------------- When **Pin11** is input into high voltage, the transistor will be switched on, and the collector will output low level. When there is a level difference between the two pins of the buzzer, the buzzer is ringing. When **Pin11** inputs low power level, the transistor is cut off and the collector is at high level, here, both ends of the buzzer are at high level, the buzzer will be silent. .. image:: media_pi/image224.png :width: 800 :align: center **Build the Circuit** ------------------------ .. image:: media_pi/image141.png :width: 800 :align: center **For C Language Users** --------------------------- **Command** ^^^^^^^^^^^^ 1. Go to the folder of the code. .. raw:: html .. code-block:: cd /home/pi/electronic-kit/for-raspberry-pi/c/Lesson_10_ActiveBuzzer 2. Compile the code. .. raw:: html .. code-block:: gcc 10_ActiveBuzzer.c -lwiringPi 3. Run the executable file. .. raw:: html .. code-block:: sudo ./a.out Now, you may hear the buzzer beep. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`C code is not working?`. **Code** ^^^^^^^^^^^ .. code-block:: C #include #include #define BeepPin 0 int main(void){ if(wiringPiSetup() == -1){ //when initialize wiring failed, print message to screen printf("setup wiringPi failed !"); return 1; } pinMode(BeepPin, OUTPUT); while(1){ //beep on digitalWrite(BeepPin, HIGH); delay(100); //beep off digitalWrite(BeepPin, LOW); delay(100); } return 0; } **Code Explanation** ^^^^^^^^^^^^^^^^^^^^^ .. code-block:: C 12. pinMode(BeepPin, OUTPUT); Set the pin connected to the buzzer to **OUTPUT** mode. .. code-block:: C 16. digitalWrite(BeepPin, HIGH); When BeepPin is at high level, the base pin(b pin) of the connected transistor inputs high level and the collector pin(c pin) output low level. That is, when the cathode of the buzzer is at low level and the anode of the buzzer is connected to a 5V high level, the buzzer sounds. .. code-block:: C 19. digitalWrite(BeepPin, LOW); The **BeepPin** is connected to the transistor and then to the cathode of the buzzer. When BeepPin is low level, the base pin (b pin) of the connected transistor inputs low level, then the collector pin(c pin) outputs high level; that is, when the level at both ends of the connected buzzer is high, the buzzer is silent. **For Python Language Users** ------------------------------- **Command** ^^^^^^^^^^^^^ **1.** Go to the folder of the code. .. raw:: html .. code-block:: cd /home/pi/electronic-kit/for-raspberry-pi/python **2.** Run the code. .. raw:: html .. code-block:: sudo python3 10_ActiveBuzzer.py Now, you should hear the buzzer beep. **Code** ^^^^^^^^^^^^ .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``electronic-kit/for-raspberry-pi/python``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python import RPi.GPIO as GPIO import time BeepPin = 17 def setup(): GPIO.setmode(GPIO.BCM) GPIO.setup(BeepPin, GPIO.OUT, initial=GPIO.LOW) def main(): while True: # Buzzer on (Beep) GPIO.output(BeepPin, GPIO.HIGH) time.sleep(0.1) # Buzzer off GPIO.output(BeepPin, GPIO.LOW) time.sleep(0.1) def destroy(): # Turn off buzzer GPIO.output(BeepPin, GPIO.LOW) # Release resource GPIO.cleanup() # If run this script directly, do: if __name__ == '__main__': setup() try: main() # When 'Ctrl+C' is pressed, the child program # destroy() will be executed. except KeyboardInterrupt: destroy() **Code Explanation** ^^^^^^^^^^^^^^^^^^^^^^ .. code-block:: 1. GPIO.setup(BeepPin, GPIO.OUT, initial=GPIO.LOW) Initialize the pin connected to the buzzer to output mode and set it to the default low level. .. code-block:: 1. GPIO.output(BeepPin, GPIO.HIGH) The **BeepPin** is connected to the transistor and then to the cathode of the buzzer. When BeepPin is at high level, the base pin(b pin) of the connected transistor inputs high level, then the collector pin(c pin) outputs low level; that is, when the cathode of the buzzer is at low level and the anode of the buzzer is connected to a 5V high level, the buzzer sounds. .. code-block:: 1. GPIO.output(BeepPin, GPIO.LOW) When **BeepPin** is at low level, the base pin(b pin) of the connected transistor inputs low level, then the collector pin(c pin) outputs high level; that is, when the level at both ends of the connected buzzer is high, the buzzer is silent. **Phenomenon Picture** ---------------------------- .. image:: media_pi/image142.jpeg :width: 800 :align: center
