.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Lesson 10 4N35 ======================= **Introduction** -------------------- The 4N35 is an optocoupler that consists of a gallium arsenide infrared LED and a silicon NPN phototransistor. When the input signal is applied to the LED in the input terminal, the LED lights up. After receiving the light signal, the light receiver then converts it into electrical signal and outputs the signal directly or after amplifying it into a standard digital level. Thus, the transition and transmission of electricity-light-electricity is completed. Since light is the media of the transmission, meaning the input terminal and the output one are isolated electrically, this process is also be known as electrical isolation. **Components** --------------- .. image:: media_arduino/image171.png :width: 800 :align: center .. image:: media_arduino/image189.png :width: 800 :align: center **Experimental Principle** ----------------------------- **4N35** ^^^^^^^^^^^^^ .. image:: media_arduino/image115.jpeg :width: 400 :align: center The 4N35 is an optocoupler for general purpose application. It consists of gallium arsenide infrared LED and a silicon NPN phototransistor. What an optocoupler does is to break the connection between signal source and signal receiver, so as to stop electrical interference. In other words, it is used to prevent interference from external electrical signals. 4N35 can be used in AV conversion audio circuits. Broadly it is widely used in electrical isolation for a general optocoupler. .. image:: media_arduino/image116.png :width: 800 :align: center See the internal structure of the 4N35 above. Pin 1 and 2 are connected to an infrared LED. When the LED is electrified, it'll emit infrared rays. To protect the LED from burning, usually a resistor (about 1K) is connected to pin 1. Then the NPN phototransistor is power on when receiving the rays. This can be done to control the load connected to the phototransistor. Even when the load short circuit occurs, it won't affect the control board, thus realizing good electrical isolation. The schematic diagram: .. image:: media_arduino/image117.png :width: 800 :align: center **Principle:** ^^^^^^^^^^^^^^^ In this experiment, use an LED as the load connected to the NPN phototransistor. Connect pin 2 of the 4N35 to pin 7 of the control board, and pin 1 to a 1K current limiting resistor and then to 5V. Connect pin 4 to GND of the Uno, and pin 5 to the cathode of the LED. Then hook the anode of the LED to 5V after connecting with a 220 Ohm resistor. When in program, a LOW level is given to pin 7, the infrared LED will emit infrared rays. Then the phototransistor receives infrared rays and gets electrified, and the LED cathode is LOW, thus turning on the LED. Also you can control the LED by circuits only – connect pin 2 to ground and it will brighten. **Experimental Procedures** ------------------------------ **Step 1:** Build the circuit (pay attention to the direction of the chip by the concave on it) .. image:: media_arduino/image118.png :width: 600 :align: center **Step 2**: Open the code file. **Step 3:** Select correct Board and Port. **Step 4:** Upload the sketch to the SunFounder Uno board. You will see the LED blinks. .. image:: media_arduino/image119.jpeg :width: 800 :align: center **Exploration** ---------------- 4N35 is usually used for driving relay as well as motor circuits. As there is no direct connection between the input and output, even if a short circuit at the output end occurs, the control board will not be burnt. Have a try! **Code** ---------------------- .. raw:: html .. code-block:: arduino void loop() { digitalWrite(OptoPin, LOW); //set the OptoPin as LOW level,then the led connected on the output of 4n35 will be light delay(500); //delay 500ms digitalWrite(OptoPin, HIGH); //turn off the led delay(500); //delay 500ms } The code in this experiment is very easy to understand. Set pin 7 as Low level and the LED will light up; set it as High, and the LED goes out.
