.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _3.1.6_py_pi5:
3.1.6 Motion Control
In this lesson, we will make a simple motion sensing and controlling
device. The MPU6050 is used as a sensor and the stepper motor as a
controlled device. With the MPU6050 mounted on the glove, you can
control the stepper motor by rotating your wrist.
.. image:: ../python_pi5/img/3.1.6_motion_list.png
:width: 800
:align: center
Schematic Diagram
GPIO18 Pin 12 1 18
GPIO23 Pin 16 4 23
GPIO24 Pin 18 5 24
GPIO25 Pin 22 6 25
SDA1 Pin 3
SCL1 Pin 5
.. image:: ../python_pi5/img/3.1.6_motion_schematic.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../python_pi5/img/3.1.6_motion_control_circuit.png
**Step 2:** Open the code file.
.. raw:: html
.. code-block::
**Step 3:** Run.
.. raw:: html
.. code-block::
sudo python3 3.1.6_MotionControl.py
As the code runs, if the tilt angle of **mpu6050** on the
`Y `__\ **-**\ `axis `__
is larger than **45** ℃, the stepper motor rotates anticlockwise; if less than **-45** ℃, the stepper motor rotates clockwise.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
import smbus
import math
# Initialize power management registers for MPU6050
power_mgmt_1 = 0x6b
power_mgmt_2 = 0x6c
# Set up I2C communication with MPU6050
bus = smbus.SMBus(1) # Initialize SMBus
address = 0x68 # MPU6050 I2C address
bus.write_byte_data(address, power_mgmt_1, 0) # Wake up MPU6050
# Initialize motor pins to GPIO pins 18, 23, 24, 25
motorPin = [OutputDevice(pin) for pin in (18, 23, 24, 25)]
# Set motor rotation speed parameters
rolePerMinute = 15
stepsPerRevolution = 2048
# Calculate delay between steps for desired RPM
stepSpeed = (60 / rolePerMinute) / stepsPerRevolution
# Read a single byte from the specified I2C address
def read_byte(adr):
return bus.read_byte_data(address, adr)
# Read a word (2 bytes) from the specified I2C address
def read_word(adr):
high = bus.read_byte_data(address, adr)
low = bus.read_byte_data(address, adr + 1)
val = (high << 8) + low
return val
# Read a word in 2's complement form
def read_word_2c(adr):
val = read_word(adr)
if val >= 0x8000:
return -((65535 - val) + 1)
return val
# Calculate Euclidean distance between two points
def dist(a, b):
return math.sqrt((a * a) + (b * b))
# Calculate Y-axis rotation
def get_y_rotation(x, y, z):
radians = math.atan2(x, dist(y, z))
return -math.degrees(radians)
# Calculate X-axis rotation
def get_x_rotation(x, y, z):
radians = math.atan2(y, dist(x, z))
return math.degrees(radians)
# Get tilt angle from MPU6050
def mpu6050():
accel_xout = read_word_2c(0x3b)
accel_yout = read_word_2c(0x3d)
accel_zout = read_word_2c(0x3f)
accel_xout_scaled = accel_xout / 16384.0
accel_yout_scaled = accel_yout / 16384.0
accel_zout_scaled = accel_zout / 16384.0
angle = get_y_rotation(accel_xout_scaled, accel_yout_scaled, accel_zout_scaled)
return angle
# Control stepper motor rotation
def rotary(direction):
if direction == 'c':
# Clockwise rotation sequence
for j in range(4):
for i in range(4):
if 0x99 >> j & (0x08 >> i):
motorPin[i].on()
motorPin[i].off()
time.sleep(stepSpeed)
elif direction == 'a':
# Anti-clockwise rotation sequence
for j in range(4):
for i in range(4):
if 0x99 << j & (0x08 >> i):
motorPin[i].on()
motorPin[i].off()
# Main loop for continuously reading tilt angle and controlling motor
angle = mpu6050()
if angle >= 45:
rotary('a') # Rotate anti-clockwise for positive tilt
elif angle <= -45:
rotary('c') # Rotate clockwise for negative tilt
# Turn off all motor pins on keyboard interrupt
for pin in motorPin:
pin.off()
**Code Explanation**
#. The script begins by importing necessary libraries. ``gpiozero`` for controlling the GPIO pins, ``smbus`` for I2C communication, ``math`` for mathematical operations, and ``time`` for delays.
import smbus
import math
#. Sets up I2C communication with the MPU6050 sensor. ``power_mgmt_1`` and ``power_mgmt_2`` are registers for managing the sensor's power. The sensor is "woken up" by writing to ``power_mgmt_1``.
power_mgmt_1 = 0x6b
power_mgmt_2 = 0x6c
#. Initializes the GPIO pins (18, 23, 24, 25) on the Raspberry Pi to control the stepper motor. Each pin is associated with a coil in the motor.
#. Sets the motor's rotations per minute (RPM) and the number of steps per revolution. ``stepSpeed`` calculates the delay between steps to achieve the desired RPM, ensuring smooth motor operation.
rolePerMinute = 15
#. These functions are used for I2C communication. ``read_byte`` reads a single byte from a given address, while ``read_word`` reads two bytes (a word), combining them into a single value using bitwise operations (``<<`` and ``+``).
def read_byte(adr):
def read_word(adr):
return val
#. This function converts the read word into a 2's complement form, which is useful for interpreting signed values from sensor data. This conversion is necessary for handling negative sensor readings.
if val >= 0x8000:
return val
#. ``dist`` calculates the Euclidean distance between two points, used in the rotation calculations. ``get_y_rotation`` and ``get_x_rotation`` calculate the rotational angles along the Y and X axes, respectively, using the ``atan2`` function from the ``math`` library and converting the result to degrees.
def dist(a, b):
#. This function reads the accelerometer data from the MPU6050 sensor, scales the readings, and calculates the tilt angle using the ``get_y_rotation`` function. The function ``read_word_2c`` reads sensor data in 2's complement form to handle negative values.
def mpu6050():
return angle
#. The ``rotary`` function controls the stepper motor rotation. It executes a stepping sequence for either clockwise or anti-clockwise rotation, based on the ``direction`` parameter. The sequence involves turning specific motor pins on or off in a pattern.
for j in range(4):
for i in range(4):
motorPin[i].on()
motorPin[i].off()
for j in range(4):
for i in range(4):
motorPin[i].on()
motorPin[i].off()
#. The main loop continuously reads the tilt angle from the MPU6050 sensor and controls the motor's rotation direction based on the angle. If the program is interrupted (e.g., through a keyboard interrupt), it turns off all motor pins for safety.
angle = mpu6050()
if angle >= 45:
elif angle <= -45:
pin.off()
